EM TuningSky Insurance
    Feb 2011
    Aberdeen
    96
    MFSW Coding Help
    Looking for a bit of coding help.
    I have fitted a flat bottom steering wheel out of a TT to my 2005 A3 sportback, I also upgraded the slip ring (1K0 959 653 D) and steering ECU (8P0 953 549 F) after discussions with Mike Foster on here. thanks Mike.
    Anyway, I now have a few issues which I would assume are down to the lack of coding.
    Airbag light on, steering wheel light on, skidding car light on.
    The steering is now heavy, horn doesnt work, multi function doesnt work, illumination doesnt work.
    I have someone who has VCDS but he was asking what the codes would be.
    Thanks in advance.
    May 2009
    south yorkshire
    628
    sure it can be done with the long coding helper in vcds, steering wheel light and abs light will go off on there own after doing basic settings on them
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Yeah long coding helper should show you how to do it properly mate.
    8P2 S3
    gynads's Avatar
    Oct 2009
    338
    Did this sort it coling? Had the same issues
