Badger5EM Tuning
Results 1 to 11 of 11
    Mar 2009
    East Ayrshire, Scotland
    15
    Unhappy Engine dead...2.0TFSI - Result of oil pressure light coming on.
    Need some help....my engine died yesterday in my A3, 2.0TFSI 06 plate, it has 93K miles on it.
    Over the last few weeks the oil pressure warning light kept coming on and then going out, had it checked out at a VAG specialist and it didn't come on when they checked it. Yesterday when going home from work it came on for a few seconds and then the engine cut out.
    I got it taken back to the garage and the timing etc is still correct and the belt still intact, however there is no compression in any of the cylinders?any ideas as I now need to get them to take the head off and have a look.
    Plus I am sure there must be a problem with the oil pump and pick up.
    Thanks in advance...and repair estimates if you think you know what it is would be good aswell!
    Cheers.
    Adam
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    well its a comon problem for the pick up pipe to block up
    you realy should have had the sump off and pick up pipe replaced when your light came on
    807
    Interested to see if the vag specialist did a scan for fault codes... i have no idea though
    bez101's Avatar
    Jul 2008
    8,491
    when the pickup gets blocked it dont show on vcds
    807
    But, surely if the light comes on it will log an intermittent DTC? (may not be a relevant DTC, but one nonetheless)
    bez101's Avatar
    Jul 2008
    8,491
    no it will only log if its a fault with the sensor
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Oil pressure is a mechanical fault, not an electronic one.
    The Engine ECU doesnt know nor care about oil pressure.
    The engine is probably full of sludge due to lack of servicing, which has blocked the oil pickup and caused low pressure.
    NEVER drive a car with oil pressure problems. Had you fixed this when it first flickered on, you'd have had a small bill to change the oil pump. You now probably need a new engine.
    TD5 Land Rover Defender build
    807
    Interesting i assumed anything which caused a light would log a code. Hope the OP can get it sorted....
    Mar 2009
    15
    I did take it to them a short time after it first came on and they said they would check the pipe etc so I really hoped that it would have been ok. I know it doesn't show up on the scan. I do have a comeback if it turns out that its oil pressure related as the last job sheet/invoice stated at the bottom that they had checked for the fault and found nothing as I requested.
    The oil is fine and it is serviced regularly at Audi/or a specialist so can't be that.
    I am awaiting a phone call back as I have now asked them to take the head ans sump off to find the problem. It still hand cranks over but no compression.
    Thanks for the replies.
    Mar 2010
    Cleveland, North East
    214
    No compression in ANY of the cylinders?
    Willing to bet money they find the hydraulic lifters have seized up causing the valves to stick hence no compression.
    I've a very cheap block/head from a 30k crash damaged 2.0 TFSI if you find you need it....
    Mar 2009
    15
    Quote Originally Posted by Cyrix View Post
    PM'd
