Badger5Monster Motorsport
    Feb 2011
    41
    Overboost condition 2.0 tdi Vagcom results inside limp mode
    i was on 3rd gear. from about 1500 revs to 4000
    Does this show overboost. it has only happened twice up a hill
    car is remapped
    Oct 2003
    up north...
    767
    overboost is usually sticky vanes in the turbo - needs a good clean and probably ultimately a replacement turbo.
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    27,113
    If I could see the numbers would comment lol
    Feb 2011
    41
    Arrow
    this was from about 1500 to 4000 revs in 3rd gear
    27,113
    Boost seems all over the place there mate, under & over in the split seconds its logging, I would check all components along the way from airbox through to intake manifold, which of course includes the turbo, which is 1 of the most well known culprits, but need to work along & see which one makes any difference, noticed you had egr fault aswell, have you checked vacuum pipes & egr movement/components which are also at the back of the engine right side which has cooler & actuator iirc.
    Feb 2011
    41
    Thats what i thought.. Yeah the only error i have is egr insufficient flow and turbo overboost condition
    Could it be a bad remap.. the people that did it were www.mobileecuremapping.co.uk
    What items can i check before i get the turbo refurbed? i can only see vacuum pipe to the egr
