JMB RetrofitsVolks Autos
    May 2008
    222
    audi a3 2.0 tdi 140 starter motor location?
    anybody help me with this please?
    Pictures would be great..
    Also any tips on removal replacement?
    Sportback owner
    Apr 2007
    France
    491
    johal87, the starter motor is located down below the air-cleaner housing, where the engine joins the transmission unit. Access from underneath looks convenient. If you were to purchase the Audi A3 Haynes Owners Workshop Manual 4844-384 it gives two sections on starter motor testing and starter motor removal and refitting, with photographs. See pages 5A*5 & 5A*6 for information. Hope this helps.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    27,072
    Remove starter from the top always, airbox takes 2 minutes to remove, disconnect battery 1st, then disconnect connector to starter, then undo nut holding thick cable on, then undo 2 hex bolts , then angle it up & out between pipes, reverse for new.
