Chris NottSky Insurance
Results 1 to 12 of 12
Thread: cat on a tdi
    tdi-man's Avatar
    Jul 2009
    1,589
    cat on a tdi
    how can you tell if your cat on a 140 tdi is blocked ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Same as any exhaust blockage. Lack of power,not enough exhaust fumes coming from exhaust. If in doubt just cut the frigging thing out and put a piece of pipe in. Should only cost 50-100 to do.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    johnnythepie's Avatar
    handcrankywannkyspanky
    Apr 2009
    Coventry
    2,174
    Should get a warning light in your dis.The you have to drive at about 40mph in third for a couple of miles to burn the carbon off the cat comb.It smells like bakelite.
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    tdi-man's Avatar
    Jul 2009
    1,589
    wont cutting it out damge turbo or make it over boost ?
    Feb 2007
    1,257
    Quote Originally Posted by johnnythepie View Post
    You must be thinking about a DPF not a cat. No wires connected to a cat and to burn soot out of a cat you drive fast.
    Feb 2007
    1,257
    Quote Originally Posted by tdi-man View Post
    The standard cat is free flowing so makes very little difference to exhaust pressure/flow. Changing your back box will lower back pressure and make more difference to the turbo and power then removing the cat.
    tdi-man's Avatar
    Jul 2009
    1,589
    yes i have dpf then not a cat ..probelm is im 15bhp down on power and wondering if this could be probelm or low compression ?
    Feb 2007
    1,257
    PD140 engines don`t come with a DPF.
    tdi-man's Avatar
    Jul 2009
    1,589
    doh ok...what ever is on the down pipe at the top no wires attached to it i dont think 54 plate 140
    Feb 2007
    1,257
    That`s a CAT mate like you stated in your first post.
    tdi-man's Avatar
    Jul 2009
    1,589
    ok ta....
    Apr 2009
    Coventry
    2,174
    Quote Originally Posted by devonmikeyboy View Post
    correct.sorry.
    Pass me my sock
