Hi all,
Booked in for Revo stage 2+ next week at AMD,cant wait,it will be worth the long trip i hope
Is there anything i should be looking out for,problems etc?(clutch will be done before)
cheers
Assuming you've already had the clutch done,you'd also have had the exhaust and intake sorted,plus the HPFP,but Shaun and the guys will have already advised you on all of that.
If all those things are done,then you can look forwards to a good deal of fun,but you should also be looking at the brakes and handling at this sort of time,as the suspension,diff controller and brakes all benefit from being upgraded,and will allow you to use the power better,safer and longer.
Hope it goes well, im hopefully going the stage 2+ route this year sometime. I got everything in the garage waiting, ie clutch, release bearing, fuel pump, RS4 regulator etc. Just waiting for a KMD cam follower to come
What happened to shark?
Apart from the clutch its all getting done there.suspention and brakes will come sometime soon.Will i be ok with better pads and something like drilled and grooved front disks?
Is your UK Stage II+ different to ours here in Oz for an S3?
You're mentioning upgrading the clutch for stage II+. Is that a mandatory requirement?
Our stage II+ is Tune, Downpipe or TBE, HPFP and then intake as recommended but not mandatory.
I haven't heard of anyone upgrading their clutch for a II+. Stage III yes, but not II+.
What does your II+ include and is the clutch a mandatory upgrade?
