Volks AutosEM Tuning
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Fault code 16785
    Had my car on the diagnostics machine yesterday as I had engine management light on.
    Came up with fault 16785 'insufficient egr exhuast flow'.
    I had a new EGR a few months ago so surely it cant be that again? Anyone have any experience of this fault or can give me a few pointers?
    The code was cleared and hasnt come back...yet!
    I've heard it may be related to MAF sensor?
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    This is what Rosstech say...You could check the wireing conectors ??
    16785/P0401/001025 - Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    • Reduced Exhaust Gas Recirculation (EGR)
    • Reduced Power Output/Engine running rough
    • Increased Emissions
    Possible Causes
    • Exhaust Gas Recirculation (EGR) Flow restricted/clogged
    • Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
    • Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
    • Exhaust Gas Recirculation (EGR) System faulty
    Possible Solutions
    • Check/Clean Exhaust Gas Recirculation (EGR) System
    • Check/Replace Exhaust Gas Recirculation (EGR) Valve
    • Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
