EM TuningAH Fabrications
Results 1 to 20 of 20
    dvdk's Avatar
    Jan 2011
    Slovakia
    Battery run down again ????
    Hi guys... i have problem with battery and dont know what kind of problem cuold it be... I own s3 8p 2007, and 11 months ago my battery died and i change it. And today my car started at the second turn, and again it seems like battery is running down...ive been driving yeasterday morning so battery should be charged, and temperature was about 0 degrees of celsius at night... Do u have any experiences with that? is there something i should measure to find wheres the problem and what causes my battery went down so quick??? thanks a lot..
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Get it tested before warrenty runs out. I had a Bosch one go like that, lasted 4 months and just went down hill over a day or so till it wouldn't charge at all
    Fossie
    Rhubarb Triangle
    3,969
    How do you know it's the battery ? What actually happens when you say it's run down ?
    Good cold starting and bad hot starting is a classic sign that the starter motor is on it's way out !
    If that is your symptom then there could be nothing wrong with the battery.
    dvdk's Avatar
    Jan 2011
    Slovakia
    i think its battery because at cold start i have a problems and sounds exactly like your battery lost life and after i started a motor and then turn off, it starts normally... its not starter, its not electronic, its battery in my opinion. hot start is perfect... but id like to know why new battery is low capacity after 11 months, it sucks...
    Fossie
    Rhubarb Triangle
    3,969
    Have you got Bluetooth fitted as standard ?
    I did read somewhere that there was a fault with some Audi Bluetooth modules that caused a larger than acceptable current flow even when the car was switched off. There is a thread on here about it I think.
    Sorry - can't help otherwise.
    dvdk's Avatar
    Jan 2011
    Slovakia
    no, i have nothing installed in car after production except a new seats, but thats definietly not a source of problem i will change battery again and will hope it will be much better battery than second one..
    2009 - 2010: Audi A3 8p 2008
    2010 - 2011: Audi S3 8p 2007
    2011 - now: Audi A4 Avant b8 2008
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    You need to get a drop test done on that battery. Basically it needs a heavyish load across it and someone to measure the voltage drop. If that proves ok then get your alternator output checked.
    you might also like to check your chassis earth as a poor earth will limit the current output.
    dvdk's Avatar
    Jan 2011
    Slovakia
    ok, and what numbers during drop test i should see.... whats the best practice in that batteries? i have no idea... thanks
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Well you have six 2v cells to give you 12v. On charge you might see 13.5v and maybe running lite.
    You should not see a drop much under 11.5 volt under a reasonable load like lights and ignition on. If the drop is down to 10v then its a sure sign you have a dead cell so you have Five cells at 2v.
    If you get a garage to test your battery they will put a load across it and see how far/fast the voltage drops and this will show up a shorting/dead cell.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by paddy View Post
    Paddy is right - it sounds like you may have a dead cell.
    Did you replace the battery with a brand new one ?
    If so, then it is faulty - a new car battery should last at least 5 years without a problem so take it back to the supplier !
    dvdk's Avatar
    Jan 2011
    Slovakia
    paddy. thanks for advice... so, my english isnt good and my electricity skill is at the freeze point as i understand your text, if voltage goes round 10v it means one of 6 cells is dead, if voltage goes to 8v 2 cells are dead. right? this definietly means changing a battery and old one bring to my supplier back....
    ok, and now my question: What battery can u suggest to me? because battery i have now is battery which seller recommand me and here is a result.. im not good at batteries and as i red before maybe VARTA or BOSCH are the best... and, which type? theres a lot of, plenty of batteries and i really dont know which one will fit my car and fit cars parameters... sorry, i am noob in that sphere... thanks a lot guys
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Your English is far better than my Slovakian
    Any branded make of battery should be fine. You have just had very bad luck as long as you are sure it is the battery at fault. My car is on its original battery at 7 years old now.
    Fossie
    Rhubarb Triangle
    3,969
    So did you fit a new battery? If so it is a bad one. !
    Do you have a reputable supplier you can go to ?
    I suggest that you buy any recognised make of battery that will fit the dimensions and connection positions of your car. The most important thing is to make sure it fits properly.
    27,126
    Varta Silver Ultra Dynamic, its the 1 up from the audi suggested Varta Blue battery that we have in our cars, I upgraded mine to this, supplied by audi aswell.
    Buttttt, you need to ideally do as Paddy says, then if battery is ok, you need to find the system thats causing the drop, there are 2 known systems that do this, 1st as Mike has correctly stated the bluetooth, which you dont have & 2nd the radios, not just rns-e, its happened to different radios & on different chassis not just 8P, so battery test 1st, then systems tests.
    Paddy has the original RS3 battery :P
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Hi guys, i've recently replaced my battery with a Varta Silver as my previous one was struggling to start the car. Now after only a month i seem to have the same issue where battery seems like it is draining. I scanned it on VCDs and have found a fault with bluetooth - intermitant signal. This was not there before, is my bluetooth draining my battery. If so can i just disconnect the module until i find a replacement? Also is it safe to trinkle charge the car battery in-situ without disconnecting the terminals. thanks in advance
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition Bluefin
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
    27,126
    Yeah BT modules can cause this.
    I may have a used 1 available soon.
    I would disconnect, then charge battery up fully without terminals on, then try to see if problem has gone, grab yourself a ctek charger, brilliant kit.
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Thanks Nigel. I already have a trickle charger which seems to do the business so will charge it over the weekend. Is there particular versions of the bluetooth module that have this fault so i can check which version i have.
    Ron
    Fossie
    Rhubarb Triangle
    3,969
    For future reference BlueSpark it is perfectly ok to trickle charge your battery with the terminals connected. I agree with Nige that for test purposes it will be necessary to get the battery fully charged without terminals connected but, once sorted, should you need to trickle charge it can be done in-situ (via the cig lighter if you have the plug )
    27,126
    Call me anal but as nothing in life is guaranteed, I always like to disconnect so in the event of a short or electrical issue, it doesnt filter through the car systems, but each to there own & with modern cars you'd like to think its cool
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Thanks Mike and Nigel. I will try and sort it out over the weekend. Once again thanks for your quick and sound advice guys.
    Ron
