AH FabricationsEM Tuning
Thread: Bluetooth issue
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    Bluetooth issue
    My Dads recently got another A3 but Black Edition this time and it's got Bluetooth.
    Got his phone paired to it fine but every time you get back in the car it doesn't pick the phone up automatically. Have to turn the bluetooth on the phone off and on again before the recognises it. In my car it automatically connects every time I turn the ignition on, don't have to turn bluetooth off then on again to get it work!
    Is it faulty?
    Sold: A3 2.0 TDI 170 S-line | Full leather | BOSE | Phantom Black | Bluefin
    Now: Mini John Cooper Works
    Stratts's Avatar
    Sep 2010
    Upminster, Essex
    61
    Have you checked the phone settings? Most require you to select "connect automatically" when you set up the pairing. Alternatively try it with another phone.
    On the driveway:
    Audi A3 Sportback 2.0TDi (140) Black Edition (Ibis White)
    Bluetooth/ Folding Mirrors / Storage Pack/ Rear Parking Sensors / Reversing Boot Mat / Deleted Engine Capacity / USB Connection
    Delivered on 5th November 2010
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Yep, it's more likely to be something on the phone as the Audi BT unit is pretty good. I had 2 SE phones before and never had any issues, I then got an Android phone and it could take anything up to 2 minutes to connect (unless I manually tried to connect). Since Froyo (new version of Android) I've had no problems though.
    8P2 S3
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Try pairing another phone and see what happens, that should rule out a problem with the BT itself
    Moved to the Darkside click below:
