Monster MotorsportChris Nott
    Richy_C's Avatar
    May 2010
    Derbyshire
    453
    Engine squeak, sounds like a mount, common?
    I've noticed recently that from cold there is a squeak from the engine when you let off the power. Initial thoughts were that the pedal was doing it but its definitely as the engine comes off power.
    After a mile or two it stops, anyone had this and have an answer?
    my worry is that somethings loose and once its heated up it expands so there's no play then.
    Cheers,
    Mar 2008
    Bradford, WY
    788
    Could be alternator pulley? Is squeak still there when you full lock the steering wheel when car is idling?
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Richy_C's Avatar
    May 2010
    Derbyshire
    453
    Not tried that yet, its just when moving and the engine is coming off load.
    Feb 2011
    I have exactly the same with my TT - Cold start there is a loud on-going squeak when you're off the power that goes away once the engine starts to warm up; has been happening a couple of weeks now and the best I can tell it maybe the power steering belt. Need to get it down the garage when its cold!
