Badger5Volks Autos
Results 1 to 12 of 12
    Lewbo's Avatar
    Aug 2009
    Hull
    1,045
    FBMFSW airbag wiring harness help.
    i have just purchased a FBMFSW and airbag seperatley as got them both for a very good price , my car already has MFSW so i understand i just take off my old airbag and wheel and put new ones on(is that right) but need the airbag wiring harness between does anyone know part number or where can get on from thanks.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,475
    i thought the bag loom was the same as you have mfsw already
    Lewbo's Avatar
    Aug 2009
    Hull
    1,045
    well hopefully it is i dont know, i havent taken the airbag off the wheel to have a look. can anyone confirm this?
    Current
    previous
    Fossie
    Rhubarb Triangle
    3,969
    The airbag wiring harness for the fbmfsw is different from that used on the mfsw.
    The part number you require is :- 8J0 971 589 B it's about 35 only available from Audi dealers.
    The wiring harness on your existing wheel is part number :- 8P0 971 589 Q (part now superseded by suffix P as there is now only one used for all round wheels) !
    amar06fbr's Avatar
    Vorsprung Durch Technik
    Apr 2010
    West Yorkshire
    1,033
    you can use your old wiring harness from your old mfsw.. with a few modifications...
    remove the green and orange plugs which go into the airbag itself and the other wire and plug them into your flat bottom.. but you got to rember the horn wires are the opposite around if you can post up a picture of your flat bottom air bag (back) and i will edit it and i will edit this pictures and show you were you need to fit your wiring .. and so your horn would work and multi function pedals aswell if you have them as i did my own .. (this was a wiring i did for a audi a8)
    For Sale
    climate control (double din non chrome)
    Black roof lining (sportback)
    pm me for more info..
    BBM: 28E07323
    My Panoramic RetroFit
    May 2009
    43
    fbmfsw
    Getting a little confused here.
    I thought that the fbmfsw was a straight foward plug and play
    as i have just purchased a wheel complete,?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by gaz4410 View Post
    If you have bought a fbmfsw complete with airbag then provided your car has already got a 2 stage airbag (as pictured) and provided the steering module is correct then it should be plug and play. If you are replacing a mfsw with a flat bottom one then you should have the correct module already.
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    when i plugged mine in it didnt work so i used my old wiring and made a few adjustment to the wires (for the horn) and it works fine now ..
    i would had taken couple of pics of mine but my cars in dealers atm..
    For Sale
    BBM: 28E07323
    Lewbo's Avatar
    Aug 2009
    Hull
    1,045
    Quote Originally Posted by amar06fbr View Post
    hi pal here is a photo of my bag with a loom dont think its the right one tho, could you show me how to modify the one i already have please thanks
    Current
    previous
    gynads's Avatar
    Oct 2009
    338
    Is there a knack to removing the airbag connectors ?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by gynads View Post
    Flck up the little yellow tabs with a small screwdriver and just pull off !
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    896
    anyone else moved the horn wires, to get it to work?
    Growing old is mandatory, growing up is optional
