AH FabricationsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 49
Like Tree1Likes
Thread: Leaky boost pipe, 2.0 TDI - solution?
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    I know this isn't a new problem, crap VAG boost pipe seals leaking. Is there a decent solution out there though, or do people just slavishly replace them every year or two? I fully expect to have a hybrid turbo within the next year or two, and would rather have a proper circumferencial sealing clamp around my boost hoses than the rubbish Audi fitted.
    I've seen Forge hose kits, but they appear to use the same sealing technique as the VAG design, just with pretty fluoro-lined hoses. As far as I know, the quality of the hoses isn't the problem that needs addressing, so I imagine they are primarily being sold because they look s****y.
    Any thoughts?
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    Fossie
    Rhubarb Triangle
    3,961
    The latest ones are all plastic and don't leak. About 75 fitted ( takes 20 minutes )
    I had one fitted in November (but it was in Leeds where everything is better and cheaper ) !!!!!!!!!????????????
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    You had "one" fitted? What did you have fitted Mike? What are you talking about man?
    Fossie
    Rhubarb Triangle
    3,961
    Sorry heeman - thought you were talking about the pressure pipe to the intercooler on a 2005 BKD engine part number :-
    1K0 145 762 CL
    This is now all plastic and does not leak ( allegedly )
    Mar 2008
    Bradford, WY
    788
    forge do some silicons boost pipes. Or if your going to get a hybrid turbo you might aswell get a intercooler as new boost pipes will come with it. Ive got the THS cooler in mine
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    mike - I don't have ETKA so can't locate exactly which part you mean, but the specific problem I'm referring to is the sealing arrangement between the boost pipes and the intercooler/inlet, using the spring clip and O-ring. The pipe itself is okay, but as a whole host of us have experienced, the pressure seal simply isn't good enough. I found one post somewhere on the net where an Audi worker said they had brand new cars leaking oil at these seals!
    navnayyar - As I said in my PM matey, and have commented on Forge's post on this forum, the silicone hoses don't solve the sealing problem, as far as I am aware. They instruct their customers to swap the O-rings over to the new silicone hoses, because they seal in the same way. All the silicone hose kit does in this situation is replace the non-problematic standard hoses, leaving the problematic seals in place. The THS cooler allows you to fit silicone hoses using Jubilee clips, which definitely solves the problem at THAT end, but not at the intake (front of the engine, below the dipstick handle). That particular join is where I have a leak, though I haven't inspected my intercooler pipes yet.
    Fossie
    Rhubarb Triangle
    3,961
    Heeman - PM me your email address and I'll send you the ETKA page with the actual items and part numbers if you want.
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Quote Originally Posted by heeman10 View Post
    Any thoughts?
    I have this exact problem and my car is suffering from a boost leak due to this at the moment too. Before I splash 75 on the new hoses I would much rather spend more on a complete FMIC setup to replace the stock design as it is crap. Mine leaks and like you say after a while even new hoses will start to leak. Jubilee clips over pipes are much more reliable and will hold the pressure better than the VAG design.
    Does the any FMIC designed for the 2.0TFSI fit the 2.0TDI (BKD) I know a couple of people here have fitted FMIC's to this engine but I am unsure as to if there is a difference or not. If there isn't I think the TFSI cooler can be bought cheaper than this:
    FR&R Tuning| ECU Remapping| Stage 1, 2 & 3 Performance Upgrades - THS Peformance Intercooler for 2.0 TDI BKD & AZV - (Powered by CubeCart)
    compared to this:
    Front Mount Intercooler Kit GOLF MK5 2.0 TFSI FSI Turbo on eBay (end time 11-Feb-11 15:57:21 GMT)
    Joe
    Click above for my A3 Build thread!
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Oh one more thing I thought, although the Forge pipes are as you say an un-needed improvement, the connectors look like they are metal rather than plastic, surely that is a better idea? As the metal will expand/contract as the intercooler does meaning it will hold boost better?!
    Joe
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    100% they are metal...
    Forge Motorsport | Alloy Fabrication[new%20code]&cat=010103#
    Mar 2008
    Bradford, WY
    788
    Yes all tfsi coolers will go on tdi. But the hoses wint fit. Reason being you need the metal connection on the "L" hose for the tdi and not on the tfsi. S hoses is ok
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    Joe90k - Yes, the joining section of the Forge hose kit is metal, as per their pics, but it still uses the same sealing method, which is no good in my eyes. I want to change the sealing method. Fitting an intercooler which will allow circumferencial clamps to be used will solve the problem, but only at the intercooler end.
    mike - Will PM you now matey.
    ste
    reverse gear
    west midlands
    121
    hi, you can fit new seals on the intercooler pipes and fit an oil catch can to remove some of the oil out the air intake system.
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    ste - As above, brand new cars are even leaking out of the joins, because of the poor seal. Leaking oil isn't my primary concern, it's the fact that a leak of any form is occurring. It means that oil AND air are passing through what should be an airtight seal. Blown turbochargers can result from such failures, and since I plan on increasing my boost pressures further, I don't want half the turbo's effort to be put into spraying a fine mist of oil all around my engine bay at 25psi. New seals will work, for a little bit, but a Jubilee clip clamping a hose around a hard pipe doesn't fail to seal unless something goes quite wrong, and nothing needs renewing to ensure that the seal is retained for a long period of time, unlike these useless O-ring seals Audi have opted for. Can you tell I'm not a fan?
    tdi-man's Avatar
    Jul 2009
    1,587
    Fitted all new pipes with seals to mine all sorted
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    ste
    reverse gear
    west midlands
    121
    hi, i have an hybrid turbo fitted to mine along with new seals and have no signs of oil leaks where as my standard turbo with original seals used to leak quite bad so i,m happy with that
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    We're going round in circles a bit here. I'm not satisfied with having to replace pipes and seals to maintain a pressure seal. I'm asking if anyone is using a reliable pressure seal that copes with standard, and elevated boost pressures. I understand that replacing the standard seals, and on occasion, the pipes and hoses, CURES the leaks, but it's a little like plugging a leaking bucket with masking tape. It'll only last so long before it leaks again, because the problem hasn't been solved.
    Fossie
    Rhubarb Triangle
    3,961
    Did you get my PM ?
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    Yes thanks Mike, just got your email and replied, thank you for that
    Mar 2010
    Cleveland, North East
    200
    Have you considered getting rid of the lot and starting again making your pipework from scratch, you can buy pre-formed pipework, the only issue I can see is the join at the Turbo, you would probably need to have a collar alloy welded to the flange.
    On my old Mk4 golf I had problems with the pipework blowing off the intercooler, I stuck the pipework together using a a resin that set rock hard, never had an issue after that, only downside is future maintainace may be a bit of a pain.
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    You glued your boost pipes onto your intercooler?! Extreme!!! I fitted a 1.8 TDI engine into my old 1993 Fiesta, and that ran at around 24psi for a while. Pipes popping off where a minor issue initially, but the problem was easily overcome with good clean seals using Jubilee clips. I've seen some nice secure sealing/securing techniques on various 1000bhp+ drag cars, but there shouldn't be the need to implement anything extreme here, just a reliable seal for 1-2bar would be nice, and should be expected from a long-standing prestige/motorsport heritage-based marque like Audi.
    I would enjoy ripping out all the crappy standard pipework and replacing it all with custom-fabricated pipework, and have a friend who is a metal fabricator who could do a nice job of it, but I don't have the free time, nor a second car right now, to allow that kind of down-time. I wondered if there were any off-the-shelf solution to this problem.
    SimonAshley's Avatar
    South East (Dover)
    88
    I am experiencing this at the moment, well I think I am? I have oil leaking out of the joint and is making a lot of whistling noise. Is it just the one pipe and both ends of it?
    I am an apprentice engineer so have access to a wide range of o-rings at work so am going to try and fit one that is slightly thicker so will hopefully have a more positive seal, I’ll let you know how I get on.
    2009 - A4 S-line 2.0TDi
    South East (Dover)
    88
    Replaced mine today with a thicker o-rings, much harder to put the pipe back in and the noise has stopped so hopefully will last a long time.
    mozza1202 likes this.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    I just had to replace my bayonet coupling as one broke away check my latest thread. The forge ones are excellent machine quality and Audi ones are inferior in every way. They will not fall apart.
    Audi S3 8P2 Silver
    BI-Xenons - FBMFSW - Rain/Light Pack - Auto dim package - iPod Integration - 2011 Nav - Electric Folding Mirrors - Rear Park Sensors - Full Heated Leather - BOSE - Privacy Windows - 2011 Console Conversion - My11 Rear Lights - RevD Diverter - Forge DMV14T BOV - ITG Maxogen CAI - BBS CH 18s
    Denzil's Avatar
    Jan 2011
    Devon
    41
    I`m having mine replaced tomorrow! mines started to blow, always something.
    Feb 2011
    Leeds
    149
    Hi all. what are signs/symptoms that your leaking boost etc? also can you recommend a repairer in leeds
  28. #27
    Fossie
    Rhubarb Triangle
    3,961
    These guys sort out my problems :-
    www.volksworks.net
    Thoroughly recommended
  29. #28
    Denzil's Avatar
    Jan 2011
    Devon
    41
    Had pipe replaced, feel the power is back which is nice. Pipe supplied and fitted 60.
  30. #29
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    I think I'm having this problem, but I can't see any oil marks, just the whistle and dump valve sound in every gear, has any one got picks exactly where the pipe runs are located
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    Oct 2010
    69
    So when my car makes a whistle/whoop noise when I change gear is that a leaking boost pipe? Or should it do that?
    Also will this kit sort this problem?....
    http://www.audi-sport.net/vb/forge-m...ady-order.html
    Also is that kit easy to fit? Would I need any special tools?
  33. #32
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Ordered myself a set of the replacement Forge boost pipes and will try them with a brand new set of seals that I have waiting for my Turbo clean.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
  34. #33
    b19ctr's Avatar
    The King of Cannock
    Aug 2007
    Cannock
    634
    Ive just had the boost pipes fitted by Forge and I'm really pleased with them the fit is a lot better than the standard pipes the engine feels smoother and theres less noise
    Air, OZ, Tarrox, on a TDI
  35. #34
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Starting to consider those Forge boost pipes. Can you fit them yourself or do you need a garage to do it?
    VCDS USER
  36. #35
    Feb 2007
    Hampshire
    1,654
    If you can get the car up on ramps or axle stands you could fit them yourself.
    Paul
    VCDS HEX-USB+CAN
  37. #36
    Oct 2010
    69
    So would these forge boost pipes stop the whistling noise when I change gear?
  38. #37
    Feb 2007
    Hampshire
    1,654
    Fantastic service from Forge - just had my UPS tracking details for delivery tomorrow
    Not sure about whistling noise when you change gear - depends what is causing it - the Turbo will whistle slightly when producing boost.
    Paul
    VCDS HEX-USB+CAN
  39. #38
    Blueie's Avatar
    He who dears' wins!!
    Aug 2009
    Anglesey
    354
    Any pics??
    I cant read, an i cant write. But thats ok! Cause im from the west country and i can drive a tractor!
    Click here to make clicking sound
  40. #39
    Dec 2010
    110
    Quote Originally Posted by Gti Jazz Blue View Post
    Paul
    I think he means like a dumpvalve kind of noise, my car makes the same noise and I've noticed a decrease in torque when I floor it, so I'm guessing I have the same problem, for the time being I think I will try the O-ring solution to put me on until I can afford the Forge kit.
  41. #40
    S3 finatic's Avatar
    Limp mode
    Feb 2011
    Norwich
    68
    I have the same noise, Great! More money!
    O-ring change first i think, then Forge later..
    Previously known as mark_sarah
