Volks AutosChris Nott
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 99
Like Tree1Likes
Thread: Cruise Control Retrofit Guide
  1. #41
    Oct 2012
    65
    Yeh yeh, it's just she won't take time to listen on how to use it and that's it's much better/easier for cameras
  3. #42
    alexi77's Avatar
    Dec 2012
    Kent
    82
    Just had a look at your excellent guide, well done and thanks.
  4. #43
    Feb 2013
    21
    I have a 2004 3.2 Quattro with trip computer and am interested in doing this mod, would I need the wire? Thanks in advance.
    Scott
  5. #44
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    433
    Quote Originally Posted by scottmachine View Post
    Scott
    Yes i would imagine as i fitted cruise to my 2004 TDI Sport with a trip computer and it needed the wire but dont be put off its relativly easy to be honest, worth every penney too!
  6. #45
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Scott
    Hi Scott,
    do you have the 3 door or sportback?
    If sportback, then no, you do not need to install the wire as it will already be there.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  7. #46
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Dannykn9 View Post
    Hi Scott,
    Correct !
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
  8. #47
    Feb 2013
    21
    3 Door, so I'll be having to run the wire. Thanks for the quick replies. I'll post some pictures up once I've given her a good clean.
  9. #48
    alexi77's Avatar
    Dec 2012
    Kent
    82
    Hi, I have someone coming to fit cruise to my sons car tomorrow, a 3.2 quattro, and he says he is 99% sure it will need an extra module as well. I will let everyone know.
  10. #49
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by alexi77 View Post
    If it is the single grille 8p2 model (which on the 3.2 started late 2005 iirc) then no, no need for the wire. But if it is the split grill as Scott has, then yes, it will need the wire running.
    Also as a basic rule, if your car has a trip computer at least, then no new module is require, although the earlier A3's with the 1K0 module, you will find the cruise works differently(slightly).
    But if you have the 1K0 (AH) module, cruise will work as expected.
    Scott, if in London, I can do the install for you, as have done for many here and elsewhere. I will also supply all parts.
  11. #50
    Sep 2012
    Grimsby, Lincolnshire
    72
    I'd be interested to hear how the cruise works differently on the 1K0 module.
    I've retrofitted to mine, and I can get cruise working if i pull the stalk towards me and flick up or down. but the resume button doesnt work?
    I assumed i needed to install the wire?
  12. #51
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by nick9one1 View Post
    Hi Nick,
    you just answered your own question mate.
    That is how the cruise works on all the 1K0 modules except the one ending with "AH" which will work in the correct manner as per stalk instructions.
    After the 1K0 modules they all changed to 8P0 modules which cruise acts in the correct manner. So basically what I am saying is the AH of the old 1K0 module is the only one that works in the correct way as the 8P0 module.
    Also, the fact your cruise works one way or another means you already have the wire in place.
    Hope that all makes sense fella?
  13. #52
    Sep 2012
    72
    that makes perfect sense, thanks.
    so if I wanted the stalk to work correctly, I would need this?
    AUDI A3 2011 S-LINE - STEERING CONTROL MODULE - 8P0953549K | eBay
  14. #53
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    No mate, that Moduke is for 8P3 models late 2008 onwards. That is only used for steering columns without the steering angle sensor.
    You need, 8P0953549F which will also allow the retrofit of MFSW.
    This is all of course if you have the big shield airbag style wheel.
  15. #54
    alexi77's Avatar
    Dec 2012
    Kent
    82
    Thanks fellas lots of useful info.
  16. #55
    Sep 2012
    72
    Ok, another question!
    I've got the option of buying this... $(KGrHqV,!jME+s(zLvWhBQVhoTmS)g~~60_12.JPG $(KGrHqF,!o8F!YCD3ssIBQVhoL4F-!~~60_12.JPGfor the sum of £35 !
    How likely is it to have the right ecu/slip-ring? Its from 2008. And Danny, yes I do have the sheild type wheel (the airbig will hopefully fit this one).
  17. #56
    Fossie
    Rhubarb Triangle
    3,969
    That wheel is from an A4 - your airbag will not fit. However, the slip ring is likely to be ok.
  18. #57
    Sep 2012
    72
    are you sure? the seller told me its from an A3?
  19. #58
    Fossie
    Rhubarb Triangle
    3,969
    Take a pic of your wheel without the airbag and I will confirm.
    At the moment all I can say is I bought one like that for my 2006 sportback and the airbag did not fit. Turned out to be an A4 wheel !
  20. #59
    alexi77's Avatar
    Dec 2012
    Kent
    82
    Send a PM to NHN there is nothing he does not know about Audi's
  21. #60
    27,077
    That looks like an A3 one, but its difficult to be 100% sure, but as its upside down, the column is anyway, without a bigger pic cant be 100%.
    Don't know if it will be the facelift steering module fitted tbh.
  22. #61
    27,077
  23. #62
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Have to disagree with you on this one mate, the airbag fitment is different, but the give away to me is if you look closely at the steering column handle adjuster, it is infact the one from the A4/B8 and A5. You can tell by the curve on it. The A3 ones are flat which unscrew.
  24. #63
    27,077
    Ah, I just zoomed in lol, yeap Danny's right, about that one
  25. #64
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    But if it was the A3 one (which we know it isn't) then it would have had the correct module. If you look at the indicator stalk and the pattern for the high beam, it is of the pre 2009 which then became a sprung loaded one, and the module changed to "K".
    Just call me "eagle eyes" lol!
  26. #65
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    The seller is lying!! Don't waste your money fella.
  27. #66
    27,077
    In my defence, I have had an eye operation few days ago lol.
  28. #67
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Not only you good with Audi's but your a pretty good comedian too, lol! :-)
  29. #68
    27,077
    No mate, deadly serious.
  30. #69
    Fossie
    Rhubarb Triangle
    3,969
    I win !! - Like I said it's an A4 wheel and his 2006 airbag will not fit.
    Sorry to hear about the eye op. nige, hope it's been successful.
    Have another peer at the pic. of the wheel and look for the locating lugs - there aren't any !!
  31. #70
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Guess we'll have to call you Patch from now on. Only kidding mate, hope it's not too serious.
  32. #71
    Feb 2013
    13
    How much does it cost to get CC parts? How about labour if installed by audi?
  33. #72
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Moe26 View Post
    Where abouts are you mate? I offer a fully fit and supply in and around London. PM if interested. If London is too far there are other users such as Nigel (NHN) who will travel all over.
  34. #73
    Feb 2013
    13
    Im from luton so very close to you. Tried messaging you but
    "The following errors occurred with your submissionDannykn9 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
  35. #74
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Give me 5 mate, I'll send you a PM and clear my inbox.
  36. #75
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Have PM'd you mate.
  37. #76
    Apr 2012
    11
    Hello mike,
    i have a 56-2007 a3 2.0 tdi sline with trip computer. Do i need to worry about installing this repair wire?
  38. #77
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,608
    Quote Originally Posted by kai hunterwood View Post
    Hello mike,
    Nope.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  39. #78
    27,077
    No you should be fine.
  40. #79
    Apr 2012
    11
    Ok cheers guys for the quick reply
  41. #80
    Fossie
    Rhubarb Triangle
    3,969
    Sorry I couldn't get back before now but you've got your answer from the experts !
