EM TuningMonster Motorsport
    Jan 2011
    6
    Sorry another spacer question....please help!
    I bought a spacer pack 12mm front, 15mm rear from the "TT shop". It is for my Audi S3 2010. The spacers are the black anodized ones. I have the black edition 2010/2011 alloys.
    When I went to offer them up to the wheel hub and alloy wheel the wheel spacer diameter is noticably less than the diameter of the wheel hub and alloy wheel hub. Without spacers the wheel hub flows into the alloy wheel and it all matches up. With the spacer there would be a gap (change in diameter - smaller). To me, this looks odd and not what I was after or expected.
    Is this also typical of H&R and Eibach, or other brand, spacers? Surely there must be some spacers which are the same diameter as the wheel hub so they all match up?
    Any pictures, comments or suggestions welcome!
    Thanks.
    Jan 2011
    6
    Any comment chaps? Surely loads of you have spacers on the S3 8P so will know if this is normal?
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    ive got H&R's on mine and everything lines up perfectly, no steps, no gaps, all nice and smooth
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    hmmmm strange one, pictures might help?
    Moved to the Darkside click below:
    Jan 2011
    6
    Ok mate that sounds perfect, I think the step/gap is due to the TT shop sourcing them for maybe slightly older cars where the hub diameter is smaller. I am going to get the H&R ones then! Thanks.
