Volks AutosEM Tuning
Results 1 to 27 of 27
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    2004 8p headlight adjuster toggle does nothing??
    Are they controlled by fuses? I cannot adjust the headlight levels moving the spin toggle does nothing . Note my car isn't auto levelling model or anything just standard sport
    Audi S3 8P2 Silver
    BI-Xenons - FBMFSW - Rain/Light Pack - Auto dim package - iPod Integration - 2011 Nav - Electric Folding Mirrors - Rear Park Sensors - Full Heated Leather - BOSE - Privacy Windows - 2011 Console Conversion - My11 Rear Lights - RevD Diverter - Forge DMV14T BOV - ITG Maxogen CAI - BBS CH 18s
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Anyone know the relative fuse numbers? Not listed on the plastic flap on my car so I'm a bit lost
    Audi S3 8P2 Silver
    Fossie
    Rhubarb Triangle
    3,961
    Fuses are listed in the user manual.
    Sportback owner
    Apr 2007
    France
    464
    Russo, according to my Haynes manual, it is fuse 'FC5' which controls the headlight leveling. This fuse is located in the internal (passenger-side) fuse-box, and is 5 amps capacity. Hope this helps. Cheers, Geraldy212
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Thanks mate I take it the internal one is under the bonnet? Will check now
    Audi S3 8P2 Silver
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Ok had a look there was no fc5 f5 was closest but was 30amp fuse in there checked all other 5s present and was intact. Bit confused now but will have a peek in my manual
    Audi S3 8P2 Silver
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Checked my manual and headlight range level is f38 10 amp red fuse. Checked it and it was fine. What else could be a problem?
    Audi S3 8P2 Silver
    Fossie
    Rhubarb Triangle
    3,961
    Must be different between 2004 and 2006
    My headlight range control fuse is number 5 in the fusebox to the right of the steering wheel RHD model (in the box behind the end dash panel) and is 10 amp
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Mike is this for manual adjustment? Not auto levelling model? For toggle switch next to dash illumination adjuster?
    Audi S3 8P2 Silver
    Fossie
    Rhubarb Triangle
    3,961
    Yes - description in the book says - Fuse 5-Automatic headlight range control, AFS control unit (advanced front lighting system)/manual headlight range control 5/10 amps.
    Therefore I can assume that the manual adjustment is 10 amps.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Just checked the driver side fuse box and number 5 was empty although behind the cover it says brake clutch switch. So I take it that it has changed. Mines a 53 plate
    Audi S3 8P2 Silver
    Fossie
    Rhubarb Triangle
    3,961
    Ok - so if your fuse is ok then you need to get a diagnostic scan to find the problem.
    There will be an error message that will point towards the problem. If you clear the error message and try the range control again if it doesn't work then another error message will appear.
    Then we go from there.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    F38 looks most likely but seems fine
    Audi S3 8P2 Silver
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    How much and where is the best place to get vcds?
    Audi S3 8P2 Silver
    Fossie
    Rhubarb Triangle
    3,961
    Agreed - F38 is the fuse. Totally different from my set up.
    So you need a scan.
    Fossie
    Rhubarb Triangle
    3,961
    Check out this list and see if anyone near to you. Otherwise you could always buy from NHN (member on this forum). About 240 I think.
    http://www.audi-sport.net/vb/vcds-fo...%2A%2A%2A.html
    Lewis583's Avatar
    Mar 2010
    829
    Well i was in the process of buying a lead off NHN and was quoted 249, would be better to pm him though
    Fossie
    Rhubarb Triangle
    3,961
    It was only a guess but not far out eh ?
    26,716
    Could even be the switch itself, ideally you need vcds to see if it has a measuring block to ascertain if its seeing the switch adjustments being made, this is one option.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    thats what i was thinking mate. Unfortunately i dont have the funds to get vcds atm. and the one person near me on the list that does never replied
    Audi S3 8P2 Silver
    26,716
    Strange as you have money to buy whats in your sig :P
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    hi soz for the thread hi-jack but on mine above the toggle switch the thing that usually lights up (headlight symbol) has stopped working it was flickering on and off for a while now its stopped working all together is it time for a new switch anybody got any ideas soz again russo2k5
    off the road boohoo anyone got a gearbox for me lol!!
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    no problem mate. thats fine. and LOL yeah NHN its more of a wish list its because im saving for a holiday with the GF shes the boss.
    Audi S3 8P2 Silver
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Quote Originally Posted by Russo2k5 View Post
    my wish list is alot bigger than that haha there are many many things on mine most of which i cant afford yet lol
    26,716
    I would pull the switch out & check for any loose wires 1st.
    Khufu's Avatar
    West coast of Scotland
    5,693
    the reostats sometimes go. I will have a spare headlight switch after i've fitted my xenons. Its basic one with headlight adjuster, side/dipped, front & back fogs.
    New one hasn't got aim adjuster as its for xenons.
  28. #27
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    i had the pannel off while i was fitting my footwell lights but plugged the wire back in firmly i might take it back off 2morow and see if i can see if there is anything obvious
