Volks AutosJMB Retrofits
    Mar 2010
    Towcester, Northamptonshire
    16
    Engine issue - No EML, ESP light on
    On the way home today (luckily, the end of my road) the ESP light came on on the dash, followed by the engine cutting out. Restarted the car, cut out again, restarted the car and used the throttle to keep the engine running.
    ESP light will not go out and if off throttle, the engine has a bad misfire, then cuts out after 10 seconds or so. If you use a bit of throttle, there is still a bad misfire, but doesn't cut out.
    Engine Management Light has not come on, so not sure where to start.
    Car is 2005 A3 3.2, done 63000 miles.
    Help please!
    Sep 2007
    Ellesmere Port
    160
    You need to get a dianostic done, either Audi or look for someone with VCDS near you and for beer tokens they will tell you what is found.
    Audi A3 2.0 TDI Sport, Hybrid Turbo, Sat Nav RNS-E, Bluetooth, Bose, Parking Sensors, Custom Bluefin Map, Black Diamond Drilled and Groved Front Discs, Black Diamond Preditor Pads (All Round), Roof Spoiler, Cruise Control.
    Mar 2010
    16
    Going to try to get the car in at a local specialist tomorrow, just concerned that its going to be the dreaded ABS pump issue causing the ESP light to be on, but can't think why its got the really bad misfire without engine management or EPC light being on.
    May 2010
    274
    Surely if it were the ABS pump then the ABS light would come on too?
    I just got the ESP light on about 5 mins ago.. At the end of a 2 hr drive about 3mi from home under heavy braking for a roundabout on a A road. Ideas?
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
