JMB RetrofitsSky Insurance
Thread: FBMFSW
    May 2009
    43
    FBMFSW
    JUST PURCHASED A 201O TTS FLAT BOTTOM WHEEL
    COULD ANYBODY TELL ME HOW TO REMOVE THE STANDARD MFSW. AND REPLACE WITH THE NEW ONE.
    CHEERS
    GARY
    Fossie
    Rhubarb Triangle
    3,969
    If you do a search using mfsw you will find a thread on fitting one. Flat bottom will be the same.
    Presumably you have the airbag with the new wheel and it is suitable for the airbag ecu on your car?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    it cant be done
    sell it me
    theres 2 torx screws that holds the bag on forgot the size
    look behind wheel at 3 and 9 oclock
    then theres a big torx in the middle
    prety easy
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    and that your car is an an 8P2 and not and 8P1
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
