Chris NottAH Fabrications
Thread: Shock failure
    circleswim's Avatar
    Lacks Car Funds...
    Dec 2009
    198
    Shock failure
    Has anyone actually had a damper pack in after fitting lowering springs on their S-Line shocks?
    2005 A3 S-Line 2.0 TDI 140 DSG
    Factory: Full Black Leather - BOSE- Lights Pack - Winter Pack - Arm Rest
    Mods: iTray - Black Optics Grill - UK Pressed Plates - Bluefin - Cruise Control - Lamin-X - Rear Aero Wiper - S-Line Spoiler - Black Diamond Brake Pads - Wheels Refurbed, Gunmetal Grey - Eibach Sportline Springs
    To Do: Wheel Spacers
    Dreaming Of: RNS-E - Bluetooth - FBMFSW - S3 Rear End - MY11 Rear Lights - Big Brake Kit
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Doubt it. They dont tend to pack in, they just arent "strong" enough to control the stiffer spring.
    TD5 Land Rover Defender build
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    It does make then wear much faster if fitted with incompatible spring. They'll be compressed much more even when static, which will lead to accelerated failure.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    not that i know of but its common sense really, put a set in a car with 100K on the shock you might see problems but in general id say the most are mine
    Moved to the Darkside click below:
