EM TuningMonster Motorsport
Page 3 of 3 FirstFirst 123
Results 81 to 107 of 107
  1. #81
    ~RS~'s Avatar
    Feb 2009
    1,463
    Sure is mate!
    I have found a good picture guide of retrofitting the headlamps and thinking about trying it myself. 2 things worried me, 1 location of blocks/ pins & wiring across from fusebox where feed comes in if they have explained correctly across to the CE.
    Is it hard to get the wiring across to the CE from fusebox entry? They didn't have any pics and I haven't a clue how it's feed from there to CE.
  3. #82
    Dean's A3's Avatar
    TDI S3 Hybrid
    May 2010
    261
    The only wiring done directly to my CE was the LED's from the headlights. Everything else was done under the bonnet. You have to bear in mind that pre-facelift headlights are 10 pin and facelift ones are 14 pin. I was not confident in doing this myself so I outsourced it to someone more competent.
  4. #83
    ~RS~'s Avatar
    Feb 2009
    1,463
    Hi,
    I read that the adapter 10 to 14 pin adapter kufatec do as seen in this link click me! takes care of any adaptions that maybe required under the bonnet for the headlights to connect up. Then it's a case of getting those 2 wires from harness into interior through bulkhead and wiring them into the CE and swapping out the old to upgraded CE.
    Maybe someone who done the work themselves, (cough Nige, cough Phil) can clarify this for us.
  5. #84
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,371
    Quote Originally Posted by ~RS~ View Post
    Hi,
    lol
  6. #85
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    i also dont have to rewire as i had adaptive bixenons anyway the converter plugs work but why pay for that then youre only repinning and running seperate wires
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
  7. #86
    ~RS~'s Avatar
    Feb 2009
    1,463
    So it's not a good idea to use the adapters then? Not quite sure what you meant there... Is there a better way to do it?
  8. #87
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    just its cheaper to replug thats all youre like a fiver for two plugs and wire, you know the price for kufatecs loom
    Mods
  9. #88
    26,776
    Its not quite a fiver trust me as repair wires arent that cheap these days, the cheapest is the 009 & thats 2 a pop & headlights dont use these type either, but even if kufa was cheaper, I still wouldnt use there gear.
  10. #89
    ~RS~'s Avatar
    Feb 2009
    1,463
    I think for you guys it's easier as you have a clue wtf your doing, lmafao! But for an absolute newb like me I think it's easier to just get the loom made up or from kufatec.
    Is the F module a no no as I keep seeing these come up and haven't seen 1 K yet!
  11. #90
    26,776
    & how do you think we learnt then Rich
    Sometimes with parts you have to bite the bullet, personally I had to eat the cannonball.
  12. #91
    Apr 2010
    149
    eat the cannonball LOLLLLLLL
  13. #92
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    i feel your pain nige should really start charging for all this info f will not work without errors even though the lights will work, and like nige says youve gotta start somewhere it really isnt that bad, as for the wire nige, why dont you buy it in reels?
    Mods
  14. #93
    26,776
    I do mate, I have reels, plenty of the buggers which is annoying for .5, .75, 1, 2, 3 mm etc for different loads & different colours, arrggh poxy wires lol, but the repair wires are still needed to attach to the reeled wire anyway chap for say running front to back, buying the pin ends & tools arent cheap either, the tool that is, pin ends is fun finding 1 supplier for them, but also attaching them can be a pita, but when got a chance will find a source for all, as would cut costs down & then also less soldering
  15. #94
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    i know what you mean ive been looking for a good set of pin release tools as my kit they work on everything but the audi, what brand are you using pal?
    Mods
  16. #95
    ~RS~'s Avatar
    Feb 2009
    1,463
    Little bit of tweaking needed here and there but looks pretty good so far...
    Should have all tied up by next weekend... Mostly coding and wiring, slight adjustment needed to bonnet and finishing touches... S3 badge is coming off asap lol
  17. #96
    Joereynolds89's Avatar
    2010 Facelift!
    Dec 2010
    Leicester
    165
    looking VERY nice mate
  18. #97
    Jun 2010
    Coventry/Warwickshire
    2,074
    Looks good ,My misses said is that what we are doing lmfao shes hooked ...
  19. #98
    Sep 2009
    Trotters, Peckham
    509
    your rear fender liner will look like this
    unless you buy two parts so it looks like this
  20. #99
    ~RS~'s Avatar
    Feb 2009
    1,463
    Cheers Joey Hope yours is sorted asap pal, will be great with the hybrid... my next move!
    Steve it's the only way I could have kept my car another year tbh mate, I've had it 2 years already and never held onto the same car for more than 18 months and the itch needed scratching, it was a must for me! Whatever happened to that great profile pic btw lol.
    tcardio, do you have a part number for those pieces mate, front splash/ arch covers are also required for anybody interested. I have the fronts and my S3 sills on order. As much as I hate to stick sills that say S3 on the car it looks like the only option! Will have to spray over the S3 me thinks..
  21. #100
    Apr 2010
    149
    looks great RS, post more pictures when its dun
  22. #101
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Looks wicked RS. more pics please!!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
  23. #102
    ~RS~'s Avatar
    Feb 2009
    1,463
    Will get some more pics when it's all sorted and lowered as it's still on stilts
  24. #103
    ~RS~'s Avatar
    Feb 2009
    1,463
    Well I'm still on stilts, but funds are drying up for this project so I'll have to wait a bit before phase 2 - lowering, maybe more power is initiated, lol. Here's a couple pics for those that were interested-
  25. #104
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    S
  26. #105
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Rich you already know my thoughts
    LOOKS SWEET, will look so much better lowered bet you cant wait to do it
    Dark Vader Half sibling - MyThread
  27. #106
    ~RS~'s Avatar
    Feb 2009
    1,463
    Cheers lads! Much appreciated, your right Ash can't wait to drop it!
    Lmao @ the yotube vid S3RYE :D Cheers mate
  28. #107
    Apr 2010
    149
    luks super, how did you sort the LED's in the end
