Chris NottAH Fabrications
Results 1 to 25 of 25
    Sep 2010
    Edinburgh
    40
    Red Steering Wheel Warning Light
    Got a bleep and a red steering wheel warning light displayed this evening before starting up. It went out straight away but is there everytime I switch the ignition on now. The handbook says that I must get the electro-mechanical power steering checked immediately by a qualified workshop. There doesn't feel like there is anything wrong and no lights displayed while I'm driving albeit I've only done a couple of short trips since this happened. I've got a long drive on Monday though and was wondering if I need to get this looked at beforehand or is there anyting I can check myself beforehand. Car is an 07 1.9tdi 3 door with 40k on the clock. I've recently fitted a set of steel wheels with winter tyres on them and they are smaller than the original wheels but the rolling radius is identical. Could this be anything to do with it or is it just coincidence. The original wheels are 225x45x17 the steelies are 195x65x15.
    Alan
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    Mine does that sometimes on start up and goes out straight away. I have left it as it doesn't come up with a mil light or fault codes.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    mine does this too i thought it was normal its done it for the three years ive owned the car with no problems at all
    off the road boohoo anyone got a gearbox for me lol!!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Its supposed to light up with ignition. As long as it goes out when you start the engine you have no problems.
    26,716
    lmfao paddy nice sig lmfao
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    One does ones best
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    lmfao @ paddy
    Sep 2010
    Edinburgh
    40
    Thanks everyone for the replies, strange though I've had the car 6 months and it's never been lit in all that time. I'll run with it for now and and keep an eye on it.
    Alan
    26,716
    The red steering wheel light is showing you its heating the steering wheel.
    Cue Paddy.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Well to be honest its usually Orange. If it turns red its a sign that the wheel is over heating.
    26,716
    Bloody hell mines on orange atm & seems little warm, worrying now Paddy, is there a technical bulletin for this?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    VAG/UPD 3472189UK9/10
    The red steering wheel symbol is now in line with the Red Brake symbol and Red Coolant symbol and signifies overheating.
    Care should be taken on initially holding the steering wheel following a Red Symbol pre start up. If symbol is illuminated when driving you should stop the car and switch off ignition until wheel has cooled sufficiently for the light to go out.
    Further information on this update is available from Audi GB R&R. Please quote Update No. above.
    Looks like it could be a common problem Nige
    HTH
    26,716
    Well feck me learn something new everyday huh, I'll be on the blower tomorrow to audi to ask what the fix is, if they suggest hairdryer on cold setting, then I'll give a TT owner a shout.
    Dilligaf-UK's Avatar
    Chugging along
    Nov 2010
    183
    Can the temperature be checked using a measuring block on VCDS to see where the problem lies?
    2004 A4 1.8T (190) S-Line Quattro
    FULL VCDS - HEX-USB+CAN
    26,716
    Yeah MB 999
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I will give it a look tomorrow. what i hadn't realised is all UK spec 8p's have heated steering wheels once activated with Vagcom..
    I knew US spec cars could activate using with MB911 but i hadn't realised its a UK option as well
    cheers
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Nige
    Does the Symbol stay as a round wheel if you have a FBMF wheel ? Can it be altered ?
    26,716
    I believe you need security access for that & a pair of heat resistant marigolds so as to not burn yourself.
    So many reasons to buy VCDS, spoilt for choice.
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,919
    Ohhh I have some of those marigolds! Wanna a borrow??? Will cost you though, maybe you can fix my steering wheel light as its gone brown, maybe its burnt out!!!
    26,716
    Quote Originally Posted by Sarah's A3 View Post
    Ooooh uuuuhhh, marigolds, gone brown, burnt out, did you say steering wheel sarah?
    Sarah's A3's Avatar
    5,919
    Haahaaa maybe Aythreee's best to answer this one lol I will get shouted at lol
    Hey, im wondering now, is my car telling me I have a big bum!!!! ! It keeps lighting this one up....
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I don't think you are taking this very seriously !!! next you will be laughing at my heated gear knob !
    26,716
    I saw Sub mention the GYM yesterday & like flies to ****, guess who pops up
    Sarah's A3's Avatar
    5,919
    P laughing!!!.....you lucky boy you!
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I said "GEAR" knob
