Chris NottJMB Retrofits
    Lincolnshire
    173
    Little niggle, outside door handle trim coming away (photos)
    Hi
    My A3 drivers door has a bit of trim that will not sit tight as it should. I would guess i am not the only person to suffer this. See pics. Any simple remedies. I guess i could just glue it in place. As it is it just keeps springing out and i am in the process of sorting all the little issues i have with my car.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    araldite should fix that!
    19scotty81's Avatar
    Push down and across !!!!!!!!!
    Dec 2010
    Newcastle Upon Tyne
    107
    Is it just the trim that's coming out or the door barrel itself.
    You can sometimes get it to click back on with firm pressure but if the clip is broken you'll need to replace it. Best way to check though just wip the barrel out, just inside the door there's a little plastic cover, remove it and you'll see a 15 (maybe's) torx screw,unwind the screw until you feel it getting tight again, whilst doing so wiggle the barrel and it might pop out, if not give the screw a couple of turns as if to tighten and push on the end of the screwdriver and this should release it. The clip is obvious when the barrel is out !!
    2004 A4 Avant
    Akoya Silver | 2 Graco Car Seats | Buggy In Boot |
    Lincolnshire
    173
    Quote Originally Posted by moag View Post
    Maybe, there is quite a bit of tension on the part so it would need a good squidge (and holding in place for a day or two)
