Badger5AH Fabrications
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    Door out of line after new wing fitted
    Hi Guys,
    I had a new wing fitted to my car a while ago after a little mishap and i noticed when i got above 70 i could hear wind whistling in through the top of the window. I finally got round to checking it out and it seems the door has been re-fitted a little low (about 2-3 mm) but because of this the seals aren't seating correctly at the top of the door.
    I need to adjust the door by those few mm, is it an easy job or am i going to have to take it back to the garage? I really want to avoid the garage if possible as it was done through the insurance and they are half way across the country.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Is the door sitting ok when you look at the line that runs along the length of the side of the car ie in relation to the line on the wing & rear quarter? I had a look at Elsa & it doesnt say how to move the whole door up & down but it tells you how to lift the window frame in relation to the door - this is used to reduce wind noise. Unfortunately you need a special template tool to measure it and then undo two screws, one at either end of the door (front & back).
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    Hi Khufu,
    If you look at the line you can see a definitive drop from the rear quarter to the locking end of the door.
    where did you find the info mate? did it say where i can get the tool?
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Sounds to me like lock end of the door has dropped a little rather than the whole door so it probably just a case of moving the top hinge forward a tad. Its trial and error but open the door wide, mark exactly where the top hinge is on the body and then slacken it off a bit and half close the door so you can lift the lock end thus moving the hinge forward a fraction.
    May 2010
    2,502
    i've had a door that was out of alignment on my 1.6... i didn't know how it had happened tho i recently found out that my sister had crashed it when i was abroad and my dad got it fixed quick before i got back
    took it back to Audi who lifted it a little. it can be adjusted as paddy has said. if it's had work done to it then definitely take it back to the guys who did the work.
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
