EM TuningMonster Motorsport
Results 1 to 7 of 7
Thread: Hybrid CAI
    Fast,not furious's Avatar
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Hybrid CAI
    I've mated a Forge CAI with an ITG Filter! So far,performance seems better than the original Forge set up,and i'm not suffering the annoying whistle i used to get when the original filter got wet! It seems to be flowing air more freely,with a slightly deeper growl,and a little less of the more common higher piched whoosh.
    The fog grill location of the old Forge filter is now home to a 76mm alu air duct intake,with a cold feed direct to the base of the filter. Forgive the DIY foam heat dam around the filter,it's another 'work in progress'!
    S3 Brilliant Red - 340bhp
    Custom Code Phase 2 + PSS, Autotech pump, Hybrid Forge/ITG Maxogen CAI /Reflactagold, Sprint Booster, Forge Quickshift, Forge DV, Denso Iridium sparks, PCV mod/oil catch can, R8 oil filler cap, Sachs performance clutch,Exhausts UK custom stainless TBE, Braille no-weight battery,PIAA mirror white DRL's,exterior + interior leds, AndyMac's Sub upgrade, H&R springs, VMR VB3 18x8.5 gunmetal alloys wearing BF Goodrich G-force 235/40
    IanS3's Avatar
    Interweb creep
    Jul 2009
    Geordie Shore
    306
    Do you know which ITG filter it was you got as I want to do this to my BSH intake.
    BBS SUPER RS FTW
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    I'm pretty sure it's the ITG JC60-67
    Here's the linky:ITG MAXOGEN AIRFILTER 67MM - ITG-JC60-67
    IanS3's Avatar
    Interweb creep
    Jul 2009
    Geordie Shore
    306
    Thanks mate.
    Have you seen this on ITG, as it says that filter is only rated to 270BHP
    ITG Air Filters
    I was going to go for the JC60/80
    BBS SUPER RS FTW
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,375
    FWIW,the original Forge CAI's filter can and does flow sufficient gas for 440bhp or more(I know as we tried mine with it before moving to an ITG).
    The ITG is definitely quieter,and the S3 specific model has the capacity for flowing air for 500bhp(which was one reason for fitting it,the other being mapping related),but absolute air flow should not be a limiting factor up to and beyond 400bhp,and in my case,the bhp and torque figures weren't changed between the two intake systems,with boost and mapping unchanged between swapping them over.
    Dealing with an OCD
    Feb 2008
    Rural Hampshire
    411
    Quote Originally Posted by IanS3 View Post
    Thanks mate.
    ITG Air Filters
    I may well have got it wrong,i thought i saw somewhere that the bhp rating was for normally aspirated engines? Can anyone clarify this one?
    If not,i'll be getting the 80 with hose adapters!!
    Oct 2008
    888
    Forge CAI up for sale if anyone fancies.
