Volks AutosAH Fabrications
Results 1 to 16 of 16
    eugegall's Avatar
    Oct 2008
    Guildford, Surrey
    66
    Question SD CARD slots on navi plus
    Hi All.
    Sorry to keep asking stupid questions but can i put my entire music library onto an SD card then into the unit to play all of my music?
    thanks chaps
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,420
    depends how big your music libray is
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    an then how big your cards are and how new your nav is
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Jan 2009
    234
    There is an upper limit to how many files and folders a card may have but I can't remember it. I THINK it is 400-500
    Nov 2010
    19
    Up to 2gb per slot not the 4gb HC cards
    Jan 2009
    234
    I have 4Gb SD cards, not HC and they work fine. Difficult to find them though.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,046
    Ive been unable to get 4gb Sds for ages.
    TIP:
    Make sure when you drag music folders across, that you delete any NON .mp3 files as they can confuse the RNSE.
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    161
    Not sure you need 4GB sd card since the number of song limitation prevents it go anywhere near 4GB. That is unless you keep a high bitrate.
    Cardiff, United Kingdom
    390
    I had one 2 GB card at first but then changed to a 4GB, I copied the 2 GB card to the 4 GB one and added a load more albums on top again so Id definately recomend going for the 4 GB card. I actually use 2 4GB cards now. Bought them from ebay and were well worth it.
    Jan 2009
    234
    Can you PM a link? Need some new ones but can't find any. Thanks
    390
    Couldnt find any on ebay but heres a link to another place that sells the one Im using...
    Transcend 4 GB SD Memory Card - Review - NON SDHC 4GB card - brilliant for older SD devices
    Io think I paid around 12 for mine off ebay though, new so theres a bit of a difference...
    390
    Jan 2009
    234
    Currently unavailable mate Thanks for trying though
    390
    DJAlix's Avatar
    Aug 2009
    102
    When I had a 2009 (192) RNS-E I was using the Transcend 4GB Cards. Older Nintendo branded SD cards will work also.
    If I remember correctly 4GB is the max size and they must be non SDHC. There is a limit to the number of "total" folders (including sub folders) which the unit would understand, so you need to be careful with your organisation. Sorry, cannot remember the limitation figure. There is also a limit on both the total number, individual and combined, of characters for file naming and file path, like old DOS systems it has a maximum pathname length of 64 characters (pathname = folder name(s) plus filename).
    ID3 Tags are limited to v2 or 2.2 as well, I used to set all to v1 to be honest and never had any issues. If you’re on a Mac, show all and then remove all hidden files eg the .ds_store, the RNS-E's get confused by these. cards need to be FAT32 formatted.
    I have a 2010 (193) unit now and am using SDHC 8GB cards, believe the max is 16GB per slot.
    A3 1.8TFSI Saloon S-Tronic S-Line Quattro 8V - Jan2014 (63)
    Glacier White with 19" 5 Arm Wing Wheels, Panoramic Roof, Black Fine Nappa Leather with White Stitching, Heated Seats, Storage Pack, Folding Mirrors, SD Nav, Aluminium Pedals + More!
    Previous: A3 (8P) 1.8TFSI Cabriolet S-Tronic Black Edition - Ibis White with Black Roof, Revo Stage One Plus with SDS, RNSE MKII with AMI, Cruse Control + More!
    Jan 2009
    234
    Feeler: If I managed to get some non HC 4gb SD cards, who would be interested? I live in Cyprus, so people would need to be patient. I will also need to see what quantities may be requested and what shipping will cost. If it's worth my time I'm willing to give it a go.
