AH FabricationsChris Nott
    May 2008
    214
    Some faults on my A3 2.0 TDI S line DSG, please help?
    Hi guys,
    Im back with another A3, brought it today from auction, and discovered some faults..
    AUTOTRANS
    POWER TRAIN DATA BUS - Missing Message from ABS Controller
    01316 - ABS Control Module
    004 - No Signal/Communication
    0625 - Vehicle Speed Signal
    004- No Signal/Communication - MIL ON
    0778 - Steering Angle Sensor (G85)
    000
    Freeze Frame
    The car drives fine, however the PRNDS is flashing, like theres a multitronic fault, however theres no fault coming up for that, just the ABS faults.
    ESP Light is on
    Steering Wheel light is on (Angle Sensor?)
    ABS Light is on
    Handbrake Light is flashing
    BRAKES is flashing in the middle screen, and will not allow me to bring up the range etc... Will just keep flashing no matter how long the drive
    The speedo will not move from 0, and does not tell me how fast I am going, also no miles will rise on the trip, or mileage.
    Any help would be great guys!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    the flashing sounds bad
    on both my multis when the flashing started it ended up costing
    never have another ever again
    May 2008
    214
    No gearbox faults are on.. Apart from the abs so touch wood I've been spared lol
    May 2008
    214
    Nobody got any advise on this?
    Updates - PRNDS Has stopped flashing, 3 x 30 minutes
    The range on the DIS says 0, along with any MPG reading
    The fuel needle, likes to play around and will drop, or raise as it feels.
    ADRENALINE JUNKIE ;)
    Feb 2011
    BRADFORD.
    thats your abs pump thats gone down pal :/
