Chris NottBadger5
    Reedswood
    Foggy Headlight - remedy?
    Hi
    Great to have found you guy's!
    Wondered if anyone could suggest of a quick remedy to conquer a foggy headlight, and hopefully, stop it from reocurring again? I don't want to buy a new one really!
    Thanks!
    Fossie
    Rhubarb Triangle
    3,969
    I took mine out, stripped it down completely (carefully ! ) and cleaned the whole of the inside glass.
    Made sure it was dry using a hair drier and put it all back together with silicone sealant around the glass.
    Most of the time it's ok but still clouds up sometimes depending on the weather conditions.
    Goes away in warmer weather !
    Fossie
    Rhubarb Triangle
    3,969
    Ooooops - sorry mate - just re-read your post and you were asking about headlight. I was talking about foglight !!!
    I suppose it might be the same principle but don't know if you can take it apart. Could use the hairdrier trick though !
    Good luck !
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Before a longish dry night drive, remove the access panels on the back of the headlight and the heat from the bulbs will dry them out nicely. Pop the covers back on at the end of the journey to stop any more damp getting back in....
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,122
    as mike says is a good idea we have done a few like that in work but if you do take it make sure you seal it properly otherwise you might end up with it happening again otherwise as alfie said or even with a hairdryer take off the cover at the back and the bulb and see if you can get rid of it through the where the bulb goes
    off the road boohoo anyone got a gearbox for me lol!!
