help needed could anybody tell me how to remove the double din climate control unit from my 2007 a3.
gaz4410 Registered User Joined May 14, 2009 Messages 57 Reaction score 2 Points 8 Location Newcastle upon tyne Jan 9, 2011 #1 help needed could anybody tell me how to remove the double din climate control unit from my 2007 a3.
S sub39h Registered User Joined May 19, 2010 Messages 2,502 Reaction score 8 Points 36 Location NULL Jan 9, 2011 #2 put your gear stick into Drive or 4th gear (for more space) protect the area with a towel or something open the card tray stick your hand in the hole and give the trim surround a tug and it should come off. with a long thin screwdriver to push the tabs in the top corners of all the buttons, pulling gently to loosen each corner then pull out index finger in each corner of the climate unit and give it a sharp tug. you need to use a fair bit of force remove wiring voila! http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/104649-facelift-centre-console.html check post #35
