AH FabricationsVolks Autos
    Hawkes's Avatar
    Apr 2010
    Warwick
    57
    wheel spacer sizes?
    hey guys ive got the standard tdi sport wheels on my 8p 3 dr (17 x 7.5 ET43... i think)
    ive lowered the car 30 mm and was wondering how wide i could go front and rear without rubbing problems?
    any help appreciated
    cheers
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    if the et is the same as on the S3's which i guess it prob is, then ive been told you can go upto 15mm spacers all round, even with a drop
    im running a 25mm drop on my S3 with 10mm up front & 12mm at the back and dont get any rubbing
    if you can its better to get a 2mm wider set for the back as the tack is 2mm narrower then the front, so that will balance the stance out
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    ill be going for 12mm-rear 10mm-front but my standard Pescaras are ET54 i think
    Moved to the Darkside click below:
