EM TuningVolks Autos
Results 1 to 10 of 10
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    Rear Brake Piston clock wise or anti clockwise
    Hi Guys,
    Someone's probably already answered this somewhere but I need to order parts and don't have time to hunt for the answer.
    Just about to replace rear pads, anyone know which way the pistons have to be screwed back in on an A3 05 plate 2.0TDI?
    Apparently there are tools to go both ways, one is double the price of the other.
    Ta
    Wheel Pimp's Avatar
    Jun 2010
    Stroud, Glos
    50
    You go Clockwise dude.....
    Im waiting for a caliper but had them apart to try and rescue them!
    Ming Blue S3, Silver Leather, Piano Black bits,
    Bosch Silver Top battery, De-Meshed MAF, Arctic white wheels!
    No major mods at the mo. Rods are next in line...
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    Excellent, cheers bud.
    Kill the thread?
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    One other question,
    Are there any torque bolts? size?
    Wheel Pimp's Avatar
    Jun 2010
    Stroud, Glos
    50
    Sory im a dumbass! ive just realised that this is in the 8P section! I have an 8L!
    the windback will be the same and as for torque bolts...... non i would say but there will be 8mm allen key bolts on the back of the carrier if you are changing the discs. 13mm spanner to undo the caliper bolts.....
    Just take the bottom one out and loosen the top one, the caliper should lift up like a hinge.
    not a prob mate.. hope it helps...
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    Cool, all standard stuff then.
    First time I have changed a set of Pads in 10 years and thought I read somewhere that Audi had replaced some of the old allen key bolts with torque.
    Thanks again mate
    Wheel Pimp's Avatar
    Jun 2010
    Stroud, Glos
    50
    In that case i could be wrong... Don't quote me on the 8mm allen key bits then! lol
    It's normally an idea to clean where the allen key fits with a think flat blade screwy and the gently tap the key in with a hitting stick.... they can rust abit so when you put them back in, a little copper grease on the threads will help....
    If they are torque bits do the same but dont go mad gouging them....
    have fun dude...
    May 2010
    274
    It's a clockwise rewind for the piston and the caliper to carrier bolts are 13mm with a 15mm for the nut between.
    You shouldn't need to take the carriers off unless you're touching the discs, and they are male headed torx head bolts. Don't know the size.
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    Beardo's Avatar
    Jan 2011
    Hampshire
    51
    all done, Jonay bang on with the sizes ta.
    MPP
    Jan 2009
    South Wales
    87
    Just tried change my discs and pads.
    Disc was no problem but couldn't get the piston to go in.
    tried using that tool that turns and push's the piston, after 15mins it was turning slowly but no going in.
    Good job the pads had 3/4 left on them so I had to reuse them. The discs wer the real problem.
    2005 A3 2.0 TDi sport.
    2000 Saab 9-3T - 347bhp
