Results 1 to 12 of 12
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Software Recall - Wipes REVO Software...?
    I've just been told by Audi that at my service thats due, they will also be required to carry out Recall 9778 (or 9718) Software Update to the onboard supply control unit...
    Does anybody have the faintest idea what this is? And is it likely to wipe the REVO software from my ECU?
    Cheers!!
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    No idea,but it will wipe your software and reinstall the latest revision from Audi over it.
    Banned
    Oct 2009
    SW
    2,353
    This is perfectly normal procedure.
    Audi updates maintain the integrity of the Audi supplied product.
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by PilotAudi View Post
    Thats the response I got from the div in the service dept!!
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by beanoir View Post
    Cheers!!
    The onboard supply control unit is above your accelerator pedal, it's sometimes referred to as your central electronics unit. It's full of relays and is the power distribution centre and CANBUS controller for the car. Your REVO map is in the engine ECU so you should be OK. That said REVO will put your map back on if it ever gets wiped by a dealer update.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    When i had my car mapped i was told that Audi are a fag paper away from making the map tamper proof which will stop this mapping anyway. Cant blame them really.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,044
    Quote Originally Posted by JohnS3 View Post
    Like John said, its only an ecu flash that affects the Revo map. When I had the window module software update carried out to remedy common 'leccy window gremlins' the Revo software was completely unaffected.
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,044
    Quote Originally Posted by paddy View Post
    The Evo Xs arent possible to map without being visible to the dealer. Not quite sure how, but I asked the guys on MLR forum and many still do it , and Just do without the warranty from new! I defo wont be doing it if that is the case.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Most new cars are "tamperproof" upon release, but its only so long before someone cracks the security and opens it up for mapping.
    I suspect that even if the map was visible, the dealer couldnt legally refuse a warranty claim unless the map was a likely cause.
    IE, if your roof started rusting, or the electric windows broke, they couldnt use the Engine Remap as an excuse not to fix it. If however your turbo failed, or the clutch exploded, then they could, and rightly so.
    TD5 Land Rover Defender build
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    Strange, I had a fault on my central electrics unit some time ago and they swapped it out.... Any way of checking if i got the update then?
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Cheers guys. I drove it back form the dealer today, and I just can't tell if it's been affected of not! weird I know.
    Decked - I'd just give them a call and see what they say the'll soon know if it's due for your car I would have thought. My car is Jan 10 so I don't know how the date means anything, but it was a recall apparently, but they couldn't tell me what it was going to do.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    VCDS will give you the current ECU flash installed.
