EM TuningSky Insurance
Results 1 to 11 of 11
    Audi S3 8P
    Aberdeen
    14
    8P S3 Full throttle problem??!!
    Hi Folks,
    Wondering if any of you guys have come across a prob im having with my S3..
    56 plate with 30k on the clock and has had a easy life to set the scene, but when i give the car full throttle in any gear it seems to splutter a bit after 3000rpm and its as if its strugglin to exhale or something? Turbo is comin in fine but just seems to be hesitant and not quite right....If i just go half throttle and let it gradually build up speed its fine?! Hesitant and judderyand generally not at ful power anyway and it was just recently serviced at the dealer with no issues reported and new oil etc too....
    Cheers Gnic13
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    is it like the car is stuttering.. like a misfire, or are the revs dropping a little bit and then picking up again?
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    is the car standard ie is it tuned at all
    ​She is back on the road yay!!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,384
    One possibility is the plugs,if they haven't been changed recently....another is coilpacks under full load.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Quote Originally Posted by S3Alex View Post
    interestingly, i had a misfire on my car on my car which was flagged on a rolling road day and most people assumed it was either the plugs or coilpacks, took it back to audi and it was a fault with the EPS system that was killing the power to the cylinders in an odd way, so if the car is still under warranty then its worth taking it to the dealer
    Audi S3 8P
    Aberdeen
    14
    Hi
    Thanks for your replies...No the car is standard and i replaced the spark plugs for NGK iridium ones about 1 yr ago...my car does sit for long periods every other month as im away with work so i first noticed it when the first cold snap came...It feels like a misfire but keeps going like that up the revs....Just like its holding back and a slight spluttering as it does it right the way up the revs....I was thinkin the plugs and leads to check first before i sent it into the dealer as the warranty has run out and i think they are about 90 per hour for labour alone here!
    Audi S3 8P
    Aberdeen
    14
    Jungleman - Yeah the revs drop out and it stutters...
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    when they drop, do the revs slip back down sort of 500-1000 rpm?
    27,105
    Fuel pump possibly.
    Audi S3 8P
    Aberdeen
    14
    Right, i had the car put on the diagnostic machine today and it gave the following...
    P3137 and or 12599 - as the codes that came up and it mentioned the intake manifold settings not being complete??
    Any ideas?
    Oct 2008
    888
    Sounds like plugs. Mine did this last week.
