Chris NottAH Fabrications
Thread: Tow Bar problem
    Dec 2010
    Waringstown, Northern Ireland
    36
    Tow Bar problem
    Hi, I have just bought a 2005 A3 1.9 TDI. It came with a tow bar fitted and I got it removed and noticed a square chunk had been cut out of the bumper. Would this be able to be fixed without replacing the bottom lower bumper? If I need to replace it what part do I need?
    Thanks in advance.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    just replace it
    the part number is on there very easy to remove
    27,029
    Yes, but would need to plastic weld it 1st to patch the cutout up, then fill/sand & then paint, in the end its a cheapish part about 50-60 iirc, then get painted as it comes primed iirc from my ones I bought.
    I actually wanted a towbar fitment, so bought sport lower valance that has the removable flap invisible when fitted so I could use removable towbar, then found out there was a sline valance so swapped it for that, then got my S3 bumper & as the S3 valance isnt available in towbar fitments, I made a removable flap in the valance, so I have S3 rear with removable flap for removable towbar, when not in use cant even see the removable flap, job done.
    Mar 2010
    Cleveland, North East
    210
    What is your colour code?
    I have a lower spoiler I will sell you from my car in good condition, I'm removing it to fit one with a removable section for a detachable towbar.
