Sky InsuranceAH Fabrications
    Wozski's Avatar
    480
    Fitting a pollen filter....
    Arghhhh!
    Im fitting one of these and its not playing ball
    angle side to the right and slide in - if only it would do that!
    Has anyone got any advice as i dont want to bend crease the filter
    cheers
    26,774
    TBH mate should slide in there easily, you sure you got it round the right way, get your nose in there with a torch the plastic moulding 1st & check you have it correctly positioned.
    Sep 2007
    Ellesmere Port
    160
    Agree with NHN, It should just pop in, may sound stupid but have you checked it against the old one to check it's not bigger and they gave you the wrong one???
    Audi A3 2.0 TDI Sport, Hybrid Turbo, Sat Nav RNS-E, Bluetooth, Bose, Parking Sensors, Custom Bluefin Map, Black Diamond Drilled and Groved Front Discs, Black Diamond Preditor Pads (All Round), Roof Spoiler, Cruise Control.
    Wozski's Avatar
    480
    ok guys i have checked and double checked
    It was the same as the last one put in there
    1KO 819 644 B
    It does not want to go in
    is there a nack to doing this - lol listen to myself....
    Wozski's Avatar
    480
    sorted!
    Changing it was easy BUT..... I had to put it at an offset and then wiggle it in - thanks for your help guys
