Sky InsuranceVolks Autos
Results 1 to 11 of 11
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    Engine Coolant temp sensor circuit 1 high a3 tdi 2.0?PO118
    my eml came on about 2 month ago(700 mile ago)
    so i scanned it and got
    PO118 engine coolant temp sensor circuit 1 high
    So i removed the code and forgot about it whilst waiting for audi to get back to me.
    700 mile later it just popped up again!
    So got same code etc.
    And ive ordered one through ecp!
    Question Is where is it on the block?
    What colour is the sensor im looking for?
    The light came on after a cold start up
    2.0 tdi a3 04
    Banana Armour
    Aug 2009
    171
    BUMP!!!!
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    open the bonnet and its located just inside one of the 2 pipes which runn along the right side of engine,between the engine cover and the airbox
    .Google Image Result for http://www.themotorreport.com.au/wp-content/uploads/2009/03/2009-skoda-octavia-0014.jpg
    Full leather/19"wheels/cruise/
    Banana Armour
    Aug 2009
    171
    What colour is it? Thanks
    Banana Armour
    Aug 2009
    171
    is it located at line 1
    or line 2?
    ive looked around at both lines
    theres a few sensors at front of block
    but none at the side where vw754 is saying(right hand side block above gearbox)
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    Quote Originally Posted by aterro View Post
    or line 2?
    LINE 1
    Banana Armour
    Aug 2009
    171
    Where then? Above gearbox on side of block?
    Banana Armour
    Aug 2009
    171
    Is it in a pipe? Pushed in?
    Banana Armour
    Aug 2009
    171
    Found it!
    Another question.
    Should the thermostat housing?where the pipes goes into. Has a bolt where the wiring attaches
    Mine isn't sealed? Should it be sealed with sealant?
    I took the one bolt out nd coolant was escaping!
    Jul 2012
    Shropshire
    32
    Found it!
    Another question.
    Can you shed any light on where you found this sensor? I've had a look around (moon light with torch!) but couldn't find it. My eml has just popped on and vcds is saying the coolant sensor is faulty.
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    ...........theres one onthe rad aswell,common one is in line 1 though.its exactly where line 1 is,theres a pipe the sensors in the pipe,u cant miss it it will have a plug going to it.
    Quote Originally Posted by Blacky165 View Post
