EM TuningBadger5
    imported_trident21
    My car won´t start.....
    Suddenly my car doesn´t start, when you try to start it the electric starting engine only revs the engine one rev and then there is a relay on the starter engine that klicks at a speed of 10 - 100 per second. And it causes some electric faults, the luggage looks and the clock resets but not the datum! Any ideas what causes this? Will have to take the car to the dealer tomorrow!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: My car won´t start.....
    Good idea take to dealer sounds clinical,sorry to waver from the point i am going to Stockholm on the 16th of January could you tell me what the weathers like at that time (Going to one of the oldest Museums there to do Scottish Dinner) (Burns)
    imported_trident21
    I hope that I have found the fault! I think the battery is out of power. Hope the car starts tomorrow after some charging.
    About the weather?
    Hard to say 3 weeks before, could be a meter of snow or it could be 5 - 10 degrees Celsius? But the law says that you most have winter tires if the journey doesn´t start or end in another country! Hope you will have a nice visit here in Sweden.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    If you think is your battery something must have caused the charge to go out of it ???
    Apr 2004
    Glasgow
    23
    I have a March 04 A3 1.6 Mpi. One month after purchase the car would not start. Battery was completely flat. RAC and Audi Assistance were called. The problem was eventually identified as the rear brake light switch sticking in the on position. The switch was replaced and battery charged. I have not had any problem since. It seems an obvious thing to check but it took some time for the professionals to correctly identify the problem.
    Check your brake lights.
    Mar 2003
    UK
    426
    Yep. I'm sure it's the battery. But probably not that it has drained itself, more that one of the connections has come lose. It happened to me 3 months into ownership. Audi Assit chap said that as they ship the cars with one disconnected, the dealer may have only attached the connection and not tightened properly. A diesel needs a lot of juice to start, and so even a slightly dodgy connection will prevent it from starting.
