Monster MotorsportChris Nott
Results 1 to 7 of 7
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Uprated clutch - Helix stage 1
    Looking at uprated clutches and it seems that everyone on here is going down the Sachs route.
    Been looking at an alternative in the form of a Helox stage 1 clutch.
    Helix Stage 1 Uprated Clutch Kit 2.0TFSi | Backdraft Motorsport
    Anyone had exerience of these?
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    southbend
    with LWFW
    JamesS4cab's Avatar
    Mar 2008
    1,122
    The price differential between the southbend and the Helix is quite significant isnt it?
    bez101's Avatar
    Jul 2008
    8,492
    yes but you get what you pay for iv run helix and killed them had the southbend stage 1 in a a4 for 18 mth and all ok
    got 1 in my b7 over 9mth now and still ok
    used helix in a gsi astra a4 a4 18T and just killed them under 3 mth
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    I would have to agree i've not heard great things about Helix clutches. If mine was a stage 2 or stg2+ S3 and I wanted longevity from a clutch that I did not have to baby, that could take abuse I deff go with a Southbend & SMF set up, plus they have so much choice from conventional drive plates to paddle plates for drag dracing, but minimum there basic model can handle is 400lb ft!
    S3_Alex admits to driving his car very carefully- no low RPM /high load driving and no hard launches, that's only why his Sachs Organic is coping with over 400 lf bt torque . On VW Vortex most people running BT setups on 2.0TFSIs are using Southbends with no probs.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    May 2009
    47
    You can also consider Spec clutches:
    Review: Spec Stage 3+ Clutch
    bez101's Avatar
    Jul 2008
    8,492
    stage 3 and not a prob
