AH FabricationsSky Insurance
Results 1 to 12 of 12
    ~RS~'s Avatar
    Feb 2009
    1,463
    WANTED! Passenger side Single Xenon, Ballast & ignitor
    As the title says, cash waiting!
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    You may need to state if it's for a bi xenon set up or not as they could be different.
    ~RS~'s Avatar
    Feb 2009
    1,463
    As the title says SIngle Xenon
    Nice car btw
    Edit> Just found this ballast inc ignitor that says it's a direct replacement for the OEM one, although it doesn't have the square type ignitor as the OEM one is.
    35w Xenon Hid Ballast kit D2 replacement For AUDI on eBay (end time 29-Dec-10 13:31:11 GMT)
    Will that be OK? Anybody tried one?
    ~RS~'s Avatar
    Feb 2009
    1,463
    Bloody pics!
    Here's what I'm after, without bulb-
    Can the back cover, missing in next photo, be bought from anywhere? Audi, part no. if so cheers!
    ~RS~'s Avatar
    Feb 2009
    1,463
    TTT
    27,096
    That aftermarket single side kit wont work diagnostically as the other side, which may cause you more issues than you need, you'd need both sides to be the same so the car likes them as such.
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    I have a new unused square ignitor from a single Xenon light as per your picture.
    PM me if you're interested....
    They have replacement OEM ballasts and starters here too if you can identify which one and can't source elsewhere.
    HID ballasts for HIDS4U HID conversion kits, Hella and Valeo OEM...
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    ~RS~'s Avatar
    Feb 2009
    1,463
    Cheers Nige,
    I have since bought one from ebay.de part no 307 329 074 IIRC, the link I showed you before (same one as alfiejets posted above) says the ballasts are all the same just different PN's so I'll see if the one I bought does the job.
    Bought an ignitor from ebay.de as well, so just need headlight now. Have found somewhere that sells the headlight (no ballast etc) for 189 which looked like a decent price... may just get one from them.
    Alfiejets, I PM'd you.
    Sep 2012
    Keighley
    53
    Sorry to bring up an old thread but seems a shame to start another when I think most of the info I need is here. I've just bought a set of xenons identical to the ones in the pictures above. They dont have ballasts with them though, is the ballast in the picture the one I need? (part number 1 307 329 066).
    Sep 2012
    Keighley
    53
    Unhappy
    Somebody must know? I found this and it pretty much says there are several of the same part with different numbers AL BOSCH 1 307 329 066 OEM D2S/D2R BALLAST - HIDS DIRECT LTD Store. I don't know if they are interchangeable though; as in using one part number for the left and a different one on the right (as long as they are in the list on the link obviously) and are they even the right type?
    TDI140's Avatar
    May 2011
    1,350
    The back case is the same as a standard halogen lamp trust me ive had major issues with single xenons lol
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Sep 2012
    Keighley
    53
    Quote Originally Posted by TDI140 View Post
    I know the headlight will fit mate, the housing of the single xenon is the same as the halogens it's just the inners that are different. I just need to know what ballast I can use with them?
