akash_sky1
Had a good trip down to Star Performance in Fife today. Finally got the Autotech internals fitted a long with an RS4 Fuel pressure regulator, and the results are very impressive.
First of all, didn't have time to get any dyno runs as I needed to back to Glasgow fairly sharpish...
However had the two parts fitted above...WITHOUT new software- as Jim said my ECU needed an OEM update before he could load a newer GIAC file on to it...and there's a pretty noticeable improvement in performance.
Even on a KO3, in a mapped 2.0TFSI the standard camshaft driven fuel pump can struggle to deliver enough fuel under load especially in the mid and higher rev ranges.
So today i got the two parts fitted, and was very impressed with the tangible increase in performance and the extended power band.
AFAIK with the new pump and RS4 fuel rail, I can now hold a solid 136 BAR fuel pressure.
Now when accelerating the car pulls noticeabley harder above 4/4.5K revs right up to the red line, whereas before the top end was certainly the weak area and stuttered a tiny bit around the 5K region also.
It feels like there's a second wind at 4200ish RPMS where the power picks up and stays much stronger to the red line than it used to.
This is especially noticeable in 4th/5th 6th gears, and on a closed road I was able to hit speeds a good 6-7mph faster by a certain landmark then 2hrs earlier before the modding, at pretty much the same outside temps.
When i get the software update and a new map to account for the mods, there should be a smoother transition from 3.5-4k revs where currently the torque feels like it jumps up a sh!tload, and the midrange should become even stronger.
Jim is a very nice chap and charged a very small fee to fit the RS4 fuel rail, which at a dealership could cost you 2hours labour!
I will try to get a RR run when I finally go back for new software, but with just the hardware fitted and no new map I can thoroughly recommend these mods on a KO3 car as well, not just the KO4 engines, as can many MK5 GTI drivers.
