Hi all
Not sure if this is the correct section to post after doing a search on the forum or to create a new post as am not sure if this issue has been covered
I currently have a 2005 vehicle with 8p0 907 279 c central electric module and have wanted to upgrade to a high end 30byte module eg 8p0 907 279 k
Finding it hard to come across a k on ebay and they are very expensive from audi, has anybody tried or know if the following would fit an older 2005 vehicle?
8P0-907-279-L: 30 Byte (Highend)
8P0-907-279-N: 30 Byte (Highend)
8P0-907-279-P: 30 Byte (Highend)
8P0-907-279-Q: 30 Byte (Highend)
I believe they are for new vehicles so I am not sure if they are compatible or what work is involved to fit them?
the fault is the hardware used, in 2003 there was no rain sensors and so the control modules were wired to look for a light sensor built into the auto dimming mirror.
the newer controllers now look for a light and rain module which is separate from the auto dimming mirror. The newer module is trying to communicate with that new light&rain sensor and cannot see it so it fails.
for you to get auto dimming mirror and auto lights to work in your car again you will need the new autodimming mirror and the light and rain sensor that will actually talk to your new electrics module.
If you want this install send me a pm and i will go through all the stuff you need, along with the prices i can do this for you.
