Hi all new here and hope someone can help me out
GoldenArrow
Various Faults on A3 2.0tdi
HI all, new to the forum and owning an Audi.
I am hoping someone can help me out here with advice on whats wrong with my new car that I love apart from the following.
Recently purchased a 2004 A3 2.0tdi with some faults although I only thought she had fault one on purchasing.
1, The open door switches on the driver door is not working so not getting the headlight on alarm when getting out and no puddle lights or door open light (passengers is fine). I assume this is just a lock swap out or is it connected to another fault?
2, Now I assume that the 2 bottons on the driver door for the alarm sensors should light up when you press the buttons. Mine doesn't I dont know but possibly linked to the door lock micro switches?
3, The car has an ipod denison installed but the concert does not seem to see it as a cd changer even when pressing the cd button once or twice.
4, today whilst playing with the climate control it went off as in all the lights on it went out then they came back, also shortly afterwards the radio went off, came back on on second attempt at turning back on.
Before picking her up she had a dead battery which was replaced so dont know if any of the fault codes i got on vag com are related to that but hopefully someone looking at this will now what my problems all relate to.
Thanks in advance for any advice it will greatly appreciated as I want to enjoy driving my Audi even if its not a 2010 model.
VCDS Version: Release 908.0
Data version: 20090911
Saturday,11,December,2010,18:40:11:13314
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WAUZZZ8P Mileage: 142270km/88402miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0D5FNE0CW
Coding: 0000072
Shop #: WSC 06435 000 00000
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - Intermittent
Freeze Frame:
RPM: 1344 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 11000100
Bin. Bits: 11000000
(no units): 1.0
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 000 - - - Intermittent
Freeze Frame:
RPM: 399 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 346.0 Nm
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 061925 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000816553
Coding: 01884F00A2141000000000000000000000
Part No: 8P2 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 16187408
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
Component: KOMBIINSTR. VDO H71 0200
Revision: D01 Serial number: 2245DD01000727
Coding: 0004408
Shop #: WSC 00441 210 61830
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 00000011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 141256 km
Time Indication: 0
Date: 2010.11.09
Time: 23:38:03
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001045210110
Coding: 3D0F0B40070101
1 Fault Found:
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 44
Reset counter: 245
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D01 Serial number: AUX7Z0D5FNE0CW
Shop #: WSC 00441 210 88110
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.10 1301
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008000186D288505489AC63000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000048
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
GoldenArrow
Blimey 40 views and not even a welcome to the forum - sorry to hear of your problems fellow Audi owner.
cant help with faults I am afraid, but I too just bought an A3 with faults, so feel your pain lol
Jesus that's a lot, can't be of help I'm afraid but someone who will be along soon enough
ps best of luck with it
if it's any consolation i had the worst hangover of my life when i first read your post. i turned my PC straight off and crawled back into bed :(
i'm no good with diagnostics i'm afraid, but welcome anyways! sorry it's overdue!
Has this car been in an accident? Looks like someones tried to mend it but not very well, the faults are on one side of the car. Id clear all the faults first as they can be sorted codes from before and then run the scan again after a few days.
There seems to be a few wiring issues! I wonder if several are linked.
A saturday nights not bet night to post for Q's LOL
Now you have a copy of the faults, I'd do as suggested above & clear them all & see what returns. Some of them could have been there for years. I see the software is out of date too VCDS is up to 10.6.3, is yours a genuine lead?
I'd check all the fuses 1st & make sure none of them have been sparking due to bad connection. I'd also make sure all the multiplugs are secure into the Central Electronic module. This is under the drivers side next to the fuse box. Its the module with all the relays & wires going into it. To remove the trim there ar 3 8mm bolts, the light switch needs pushed in and rotated to the right (about 1pm) & then the whole unit can be pulled out, then its just clipped in at the top, a pull will unclip it. There is a red bar that need slid to the side to let the multiplugs come out. Im guessing that as they went out the databus error isnt to much the can signal to the modules but they werent powered hence no communication.
I know sorry if I seemed impatient! I was in a tizz about my car....
I didnt have time to do the checks mentioned but clared the fault codes whilst I was at work and drove home and tested again.
Leaving the following.
Sunday,12,December,2010,18:31:55:13314
Chassis Type: 1K0
VIN: WAUZZZ8P Mileage: 142280km/88408miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Coding: 0000072
Coding: 0023174
Coding: 16187408
Shop #: WSC 00000
Coding: 0011602
Coding: 0000012
Coding: 0004408
Coding: 0000048
1 Fault Found:
Coding: 0000048
1 Fault Found:
Address 56: Radio
Cannot be reached
Re is the lead genuine well it an ebay item :ohmy:
Re accident previous owner said the front driver wing was dented by a trolley in a car park and was beat back out its not to noticable unless you are really looking hard.
When i checked to see if involved in a reported accident came back clean.
I will use the car for a few days and retest.
When I get a chance to check out the other bits n bobs I will but most probably be next weekend.
thanks for the advice so far.
GoldenArrow
If the battery has been disconnected then it's likely that the windows and radio will need to be re-synchronised.
Radio will need code number and windows re-set as owner manual
I am assuming the reason the 2 alarm buttons on the drivers door do not work is because the door thinks it is shut all the time due to the faulty microswitches in the lock.
Does this seem right to you guys?
Regarding my Climate Control I am pleased/embarassed to say I was being a newbie and turned it off by taking the - down as far as it would go on the fan. RTFM!
Although the + for the fan does not work at all, flick it on auto and the fan will blow as required so can live with this as long as it does not damage anything.
Tried synch of windows but still get the fault, I must be doing something wrong will have another go tomorrow.
9
857
I
imported_ANNANBHOY
I
699
