Badger5Sky Insurance
Results 1 to 20 of 20
    Apr 2010
    182
    2004 A3 2.0 TDI juddering and struggling to start?
    hi guys i have a 2004 A3 2.0TDI on about 100k, the car sounds like its struggling to start and sometimes taking a couple of attempts to start, also when sitting on idle the car is juddering really bad, iv had a new fuel filter as the old one was really blocked up and a new throttle body, had it checked for faults but none were showing, has anyone had this problem or any suggestions for me to try to fix it.
    thanks in advance
    Dan
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    EGR could be blocked with crap plus you could try a good dose of injector cleaner.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Apr 2010
    182
    ok cheers ill try the injector cleaner and get someone to look at the egr valve, im usually good with cars but dont know my way round these engines lol
    anything else worth checking guys?
    Fossie
    Rhubarb Triangle
    3,969
    Injector wiring loom ?
    Apr 2010
    182
    could you expand on that abit please? what could be wrong with it?
    Fossie
    Rhubarb Triangle
    3,969
    If you search this forum for threads regarding juddering and rough idle you will eventually find that in a large number of cases the injector wiring loom is at fault. Apparently some of the looms were subject to intermittent failure for some reason or other and I believe Audi introduced a revised version at some stage.
    It is not that expensive to buy and, from all accounts, is relatively easy to fit although I am in the fortunate position of not having had to do this job.
    Hope this helps
    Nov 2005
    Chester,UK
    110
    How old is the cam belt on it?
    My car was quite lumpy on start up until I changed the cambelt.
    If you do a serch for Torsion value you should find posts on lumpy idle.
    The cambelt can stretch a little over time which can push the timing out slightly.
    Or it wasnt set up properly when the new belt was fitted.
    Vagcom (VCDS) or the like can measure the value and adjustments can be made as the cams on this car can be slackend off to
    1. Help fit the belt in the first place
    2. Allow a slight adjustment to get the "Torsion value" correct.
    Best watch my spelling of Torsion as well - Audi may spell it different to me!
    Apr 2010
    182
    I did search the forum but wanted to know if there was anything more simple that could be causing it.
    Off the top of my head I can't remember how old the cam belt is but would this cause the car not to start first time?
    It Took a couple of attempts to start again last night :'(
    Nov 2005
    Chester,UK
    110
    Does it start really well on a stone cold engine?
    but warm or hot it takes two goes?
    There are two starter related problems (but not lumpy idle)
    1. heat damaged starters makes them weak
    2. Audi have a hot and cold map in the ecu for starting
    When the engine is in the hot map it can be tricky to start most of them.
    I stripped mine and cleaned and greased it - that helped but didnt elimate totaly as compared to other make starters there pretty clean on the inside.
    some people have had the map adjusted by audi or when getting a aftermarket remap
    On a warm engine just try the starter once - they may be a pause followed by a climb to idle revs - works for me.
    Rough idle is a different fault though
    you have had all the right suggestions for that - there wont be anything simpler.
    Nov 2005
    Chester,UK
    110
    And when you say throttle body what do you really mean as diesels dont have a throttle body as such.
    they do have the valve that closes in the air intake when the engine is shut off - do you mean this?
    Apr 2010
    182
    Ok cheers for the suggestions, it does struggle to start alot when hot. But it does also struggle sometimes when cold? Could it be something to do with glow plugs? I'll be filling up in a couple of days so I'll put some injector cleaner iv got.
    Yeah sorry it was a valve at the front of the engine?? (I didn't change that myself someone done it for me n I watched lol) but it was full of gunk!! This didn't really make much difference though...
    Thanks for the advice so far guys
    Apr 2010
    182
    27,033
    Quote Originally Posted by devonmikeyboy View Post
    Which did you use on your bkd's Mike?
    Quote Originally Posted by gizm0 View Post
    Intake manifold flap you're referring to, although they may have swapped this, did they remove the egr & clean this fully & test ok, did they also check the egr cooler actuator at rear of engine, check glow plugs functions with vagcom?
    Starting crap when hot is usually 1 of 2 issues, coolant sensors or starter, the starters suffer from heatsoak given its strapped to the gearbox which gets fairly hot from use, thus the starter is almost a heatsink & affects possibly the coil/solenoid, I have fitted new starters to some bkd's & the new starters were a hell of a difference, also a DIY swap aswell, somethings to consider aswell as injector problems which have affected these cars too.
    Glowplugs wont affect a warm engine as they're just used on cold blocks to heat the cylinders as such, so wont be used all the time, for me its not this your problem mate, probably one of above to check.
    Apr 2010
    182
    im going to be gettng the alternator and injector wiring loom off someone i know, but hes saying theres two looms available? could anyone help me out with chich one i need or possibly give me a part number?
    cheers
    Dan
    Apr 2010
    182
    cheers
    Dan
    Apr 2010
    182
    also i heard someone mention about a sensor at the back of the engine to try unplugging and seeing if it starts ok then? could anyone tell me where abouts its located and if its accessible from just opening the bonnet?
    thanks guys
    Fossie
    Rhubarb Triangle
    3,969
    The BKD engine injector wiring loom is part number :- 03G 971 033 L
    Apr 2010
    182
    thanks what does BKD mean? sorry lol (newbie here) lol
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    Dan
    As suggested by James above.
    If the cam belt has stretched a little, the cam/injector timing will be out. This will cause a poor start, without fault codes.
    If the belt has been changed without using the correct crank tool and cam pins, the timing references will be from the old belt.
    I guess at 100k it has had a belt and water pump change? Check under the covers to see if there is any tipex marks on the pulleys, if there is it would suggest the belt has been changes without the correct tools?
    Also have the garage do a block test to check if you have any CO2 in your coolant, this could indicate the onset of a cracked cylinder head. This would give a poor idle quality when started.
    Faulty heater plugs will throw up a fault code.
    Fossie
    Rhubarb Triangle
    3,969
    All engines have a code and if you look inside the front cover of your service book you will see against engine code the letters BKD.
