JMB RetrofitsEM Tuning
    fad
    fad's Avatar
    Nov 2010
    Dartford Kent
    9
    Help with VCDS scan
    Hi all,
    Been a bit of a serial lurker since my Auction punt landed me with an A3 Sportback 2.0 TDi. I feel now is the time to come out of the woodwork and ask for some pearls of Wisdom.
    Ash kindly ran a VCDS scan following my management light comming back on after fitting my new intake flap. Please find the results of the log bellow.
    From looking at this I am feeling the EGR fault of having "insufficient flow" may mean me needing a new EGR valve. Can anyone confirm that the code bellow means this? What part of the error code should I be looking at?
    Also another fault with my passenger door has come up and despite trying to change the code values it keeps throwing up an error any ideas?
    Thanks in advance
    Fad
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    VIN: WAUZZZ8P37A003138 Mileage: 132670km/82437miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 021 LG HW: 03G 906 021 LG
    Component: R4 2,0L EDC G000SG 9179
    Revision: --H02--- Serial number: AUX7Z0F4FNF05M
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 6FE9ACE807EF
    1 Fault Found:
    001025 - EGR System: Insufficient Flow
    P0401 - 000 - -
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 131889 km
    Time Indication: 0
    Date: 2010.11.25
    Time: 10:23:54
    Freeze Frame:
    RPM: 1785 /min
    Speed: 61.0 km/h
    Load: 21.6 %
    Duty Cycle: 14.6 %
    Duty Cycle: 100.2 %
    Mass Air / Rev.: 315.0 mg/str
    Mass Air / Rev.: 670.0 mg/str
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    VCID: 73E1A0986BC7
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
    Component: KlimavollautomatH18 0300
    Revision: 337754 Serial number: 8P0820043M
    VCID: 3667598C3835
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000005816129
    Coding: E58A5F01B214100000160000160000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408B3F546AF1
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH12 0090
    Coding: 00150573
    Shop #: WSC 06314
    1 Fault Found:
    00987 - Lamp for Brake Light; Left (M9)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 38
    Mileage: 131530 km
    Time Indication: 0
    Date: 2010.11.18
    Time: 18:10:00
    Freeze Frame:
    OFF
    Voltage: 12.35 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H12 3760
    Revision: 91H12376 Serial number: 003620G0LWLF
    Coding: 0071612
    VCID: 428F355C64FD
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H34 0070
    Coding: 0002042
    VCID: 418D3A5061FB
    Part No: XXXXXXXXXXX
    Component: E0221 H07 0090
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H16 0550
    Revision: D0H16001 Serial number: 2244F001000765
    Coding: 0004413
    Shop #: WSC 01234 512 00000
    VCID: 3B7148B80317
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 300010651081D8
    Coding: 3D3F0B4207002103
    VCID: 2B5178F8F377
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H16001 Serial number: AUX7Z0F4FNF05M
    Shop #: WSC 00000 000 00000
    VCID: 3B7148B80317
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000760
    VCID: 408B3F546AF1
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.078 H07 1806
    VCID: 35655E802533
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D088505489FC63300
    VCID: 3C734BA40619
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674690580992
    VCID: F1ED2A9091DB
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000760
    VCID: 418D3A5061FB
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H52 0100
    Revision: 02S Serial number: AUZ2Z3F4011661
    Coding: 0001005
    VCID: 326F659CD45D
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000216
    VCID: 408B3F546AF1
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000216
    VCID: 418D3A5061FB
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D5576E0CD63
    Mar 2008
    Bradford, WY
    788
    I had this fault after i cleaned out my egr and manifold. I didnt bother buying a new egr so just got a delete pipe and got the egr warning light and cycle mapped out.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    fad
    fad's Avatar
    Nov 2010
    Dartford Kent
    9
    Hmm tempted by the delete pipe as my mate keeps waving a cheap remap in my face!
    Only thing thats puts me off the delete pipe is that its quite obvious in the engine bay should I wish to sell this on.
    fad
    fad's Avatar
    Nov 2010
    Dartford Kent
    9
    Bit of an update for anyone who is interested,
    I had the EGR mapped out so its no longer asociated with the car, from speaking to a couple of sources the only time you need a blanking kit is when you are going down the serious tuning route. Otherwise it can simply be mapped out of the system with no need for a blanking kit.
    I no longer have a management light or fault code and there is a massive improvement on how it drives. I am however still experiencing a shake on idle. It mainly happens when it is warm and has been driven around town. It can start off quite faint then gradually get worse. You can also notice a faint shudder when slowing down to a halt. Its also worth noting you dont actually experience the rev needle fluctuating which is wierd, you just experience a constant shake throughout the car!
    I've been told this is symtoms of injector seals or a tandum pump issue. I checked the fuel filter and it was clean....running out of ideas now!
    Any help appreciated.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    It might be the DMF, injector(s), injectors wiring loom.
    VCDS USER
    fad
    fad's Avatar
    Nov 2010
    Dartford Kent
    9
    Yes been thinking an injector loom but also timing as the belt wasnt done long ago!
    2006 A3 2.0 TDI
    WG Motorworx Stage 1 Map with EGR delete
