Badger5Sky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
    sturs4's Avatar
    Aug 2010
    186
    s3 clutch slipping with map
    hey guys,
    I went to shark and had a map done but had it taken straight off again due to the clutch slipping.Im wanting to know what clutch to fit in order for it to handle the power gains easily and reliably for years to come.its a stage 1 map giving 320hp and 444nm of torque.
    cheers
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Glad you got on ok with Ben! Sachs clutch you need lad!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Is the car under warranty?
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    Mar 2008
    Bradford, WY
    788
    Why didnt you just ask to tune it down a bit. Its easy making high numbers but difficult to get it to run right without parts messing up
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Sachs uprated clutch and a standard LUK flywheel is what you need - around 750 for the parts plus labour (6-7hour job)
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,356
    As soon as a car gets much over 300-320lbs of torque,the OEM clutch is on borrowed time.
    I've got a Sachs on mine,which has worked well with Stg2+ for over 20 000 miles,and seems to be coping with 410lbs of torque currently on Stg3.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    As mentioned you could go with an uprated Sachs clutch and OEM DMF which will give you much higher clamping force and will be able to handle up to stage 2+ power. However if you want to go above that tune and/or if you do many visits to the drag strip or loads of hard launches a single mass flywheel set up would be best. I'd go for a southend clutch in that case.
    Only prob with SMFs are increased NVH and more stress on the crankshaft at high revs.
    I've got the sachs & DMF set up and now its finally been installed properly its rock solid with no slip. Pedal weight is higher, but after its run in gets a tiny bit lighter and its easy to drive in traffic. Pretty sure my mum or sister could handle it!
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    There is evidence to suggest that later OEM clutches, ie on newer facelifts and those units replaced under warranty, are stronger and less prone to to slipping at Stage 1.
    Mine is at Stage 1 and had a OEM replacement under warranty a few weeks ago, so far so good.
    However if you are paying for the clutch out of your own pocket then an uprated unit such as SACHs etc is the answer like the guys said.
    Good luck
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Quote Originally Posted by S3Alex View Post
    hey Alex
    with your clutch you running a SMF or a DMF? did you get yours done down at AMD if so i may have a word with them and get their advice when we are down there on sunday
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,356
    Quote Originally Posted by jungleman View Post
    hey Alex
    Sachs plus LUK DMF.
    I didn't want the added problems of a SMF setup unless I absolutely have to,although if I run more power and torque later,it may well be a neccessary step.
    sturs4's Avatar
    Aug 2010
    186
    Cheers guys,
    The car is still under warranty but i thought i might aswell uprated the clutch just to give me piece of mind and reliability with the map.Is this the clutch i need?
    Clutch Kit: ZF SACHS Performance clutch - Power Clutch - Art# 999787 999502 - TTNET - Sachs Performance Parts
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    well if its coped well with stg 2 for 20k and ure new GT3071 hasnt destroyed it yet it must be a pretty stable set up. doubt ill go beyond stg 1, at least not for a couple of years
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Quote Originally Posted by sturs4 View Post
    That's the one fella. Buying one myself at the moment as it happens...
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    if people are on the hunt for clutches, how many people do you think we would need for a group buy? try and get a bit of a discount going?
    sturs4's Avatar
    Aug 2010
    186
    Quote Originally Posted by BigBird View Post
    Wicked.will that be all i need?
    Id be up for a group buy
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    i would have thought so, think your DMF may have survived because you removed the map straight away... ill be changing mine as im getting a bit of slippage on full throttle, so id rather be safe then sorry and get it all changed
    i know there was a group buy about 4-5 months ago so ill dig up that thread and find out their contact and see what i can do
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Ahh - you need someone who knows what the f**k they're talking about mate!
    For what it's worth I'm also buying a new concentric slave cylinder & an LUK DMF whilst it's all out on the floor. Just the new clutch bearing to source now. Cheapest by far was buypartsby.co.uk
    Thought about a group buy myself, but I needed it sharpish, so mine's on order & paid up now. Just keep hoping the pound strengthens more & buy from Sachs whilst they've got the free delivery on this month...
    123d MSport coupe from the company
    2007 S3 in sprint blue - gone!
    sturs4's Avatar
    Aug 2010
    186
    And a DMF.Cool see if you can find the details,im in if the price isnt stupid.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    ill do some hunting over the next couple of days and then get a thread up on both here and VAGOC see if we can some discounts going
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    I think it is you who "needs someone who knows what the f**k they're talking about" as the slave cylinder contains the thrust bearing which your on about
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
    gynads's Avatar
    Oct 2009
    338
    Any chance of posting best prices found for sachs clutch and the DMF ? Could save a few searches and possibly get us some discounts? the cheapest i have found the DMF is buypartsby
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Quote Originally Posted by gynads View Post
    how much was that?
    jsws3's Avatar
    Oct 2009
    443
    james warning 192 has a new clutch for sale pm him foe details
    REVO stage 2+ , dbilias cai , apr pump, milltek tbe special h&r springs , h&r arb's
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Quote Originally Posted by jsws3 View Post
    alright John
    is it a saches one?
    gynads's Avatar
    Oct 2009
    338
    how much was that?
    253 all in delivered
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    not bad, will have to see if they will do a group discount as well!
  28. #27
    akash_sky1's Avatar
    1,209
    I got a LUK from buypartsbuy 228 delivered maybe different to the S3s althoughthe clutches are the same.
    Waring's clutch is a sachs and its the one you want
  29. #28
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    humm odd in the price diff.... will have to give them a call and see if i can haggle
    ive just fired him over an email, see what happens lol
  30. #29
    sturs4's Avatar
    Aug 2010
    186
    Right,so just to clarify,i need,
    Sachs uprated clutch which is this
    And a new OEM DMF.
  31. #30
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Sturs - you were doing well to get 320 horses out of stage 1 - i would have been well pleased with that!! Good work.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
  32. #31
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    He's sold it now...
  33. #32
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Quote Originally Posted by JamesS4cab View Post
    Thats why I keep banging on about Shark, but nobody seems to listen! I went out in a stage 1 S3 and it was RAPID!
  34. #33
    jsws3's Avatar
    Oct 2009
    443
    alright John
    is it a saches one?
    yes bud it is drop him a pm if no reply drop me a tex and ill ring him ok mate
  35. #34
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    It's definitely sold mate! PM sent...
  36. #35
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Quote Originally Posted by N8 View Post
    Next you will be banging on about purple wheels being the new cool...........
  37. #36
    Nov 2010
    52
    If anyone wants is interested in a Clutch Masters clutch/flywheel kit I can offer very good discounts. Could even look at doing a custom FX850 Super Single for you guys, it is a setup I had CM make for the A4 1.8t and I run one in my own A4 1.8t that makes 650whp.
  38. #37
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    No I'll bang on about B6 V8 S4s being underpowered but you won't listen
  39. #38
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Well its lucky I have an S3 8p running Revo stage 2 then!!
  40. #39
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    You got the car right
  41. #40
    sturs4's Avatar
    Aug 2010
    186
    323bhp,444nm torque
