Thread: Help Required
    Flat Out
    Apr 2007
    Essex
    144
    Help Required
    Just bought a 57 plate A3 Sportback from a second hand stealer to sit along side our A4 Cab. Stealer tells me it has coming/leaving home lights. Have tried the obvious with the remote but no lights come on. Question is; Anyone live in the Chelmsford area with Vagcom that could check to see if it is installed but not enabled? Thanks in advance.
    Flat Out
    Apr 2007
    Essex
    144
    Forget previous post. What a PRAT I am. Hadnt flicked the switch next to Auto light switch. SORRY
    PaulTheo's Avatar
    Aug 2010
    Bristol UK
    126
    Is the light switch in the auto position and was it dark enough?
    Flat Out
    Apr 2007
    Essex
    144
    Lights are set to Auto. It was dark but I hadnt pressed the button under the DRL and dimming switch. All working fine now.
