EM TuningSky Insurance
Results 1 to 16 of 16
    Vertigo1's Avatar
    Jul 2006
    2,655
    Latest DIS - locking configuration?
    I've been informed by the dealer that the latest DIS on the A3 can be used to configure the locking configuration, both enabling disabling the convenience locking (i.e. single/double press to unlock drivers/all doors or just one press for all doors) and the drive-away locking (locks above 10mph, unlocks when you remove key from ignition).
    Can someone with the latest DIS confirm that they can alter these two functions?
    Cheers.
    27,114
    I seem to recall the convenience menu yes, sure it had autolocking listed, cant check mine atm as battery on bench charging.
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    Im also 99% that it has both of these. My old company A3 (8P3) had these
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
    Vertigo1's Avatar
    Jul 2006
    2,655
    Cheers guys
    slade777's Avatar
    Sep 2010
    763
    Quote Originally Posted by Vertigo1 View Post
    Cheers.
    Ive got this on my MY10 car!
    Current:
    A3 Black Edition 2.0 TDI 140
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Yeah I was about to say I think this started on MY10s, mine is MY09 and doesn't have it, although it does have the advanced DIS menu.
    8P2 S3
    Vertigo1's Avatar
    Jul 2006
    2,655
    Yeah looks like it coincided with the change to the white DIS
    TFSI's Avatar
    Born to Fish
    South Cheshire
    531
    Cheers.
    Changed mine on the DIS from unlock one door only to unlock/lock everything with one touch of the button. Auto locking at 5 mph still continues
    2013 1.4 TFSI S line 8V, Brilliant Red, Cruise Control, DIS, MFSW, Dual Climate, Leather, Front Fogs, 18in 5 Twin Spoke Alloys, Welly, Boot and Fishing Rod Racks.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I think DIS functions are a combinations of factors LOL.
    e.g.
    I have white cluster & retrofitted parking sensors but I have no settings in the DIS for it, im sure thats due to the revision of the PDC module.
    I changed to latest network module & It corrected a fault with VCDS registering a central locking fault though it worked fine, but what it did was show a cluster warning light for my convertible roof (??) that was only sorted when I upgraded the convenience module to a newer version. This in turn added new functions to the DIS for locking doors & windows, still no parking function for wipers & despite being ticked, none of this gets the suggested gears working, guessing that will be an ECU thing.
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    I have a 57 a3 and mine does this press the key once and the drivers door opens and press again and the passenger door and boots opens I think it's rather annoying how do I change this to open everything with one press?
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    27,114
    vagcom.
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    I don't have vagcom how much would I be looking at for a proper vagcom instead of the cheap stuff of eBay?
    Current
    previous
    27,114
    244
    micasb's Avatar
    Mar 2010
    312
    Quote Originally Posted by Khufu View Post
    e.g.
    Hi,
    Wich confort module did you use? So you're getting the same problem regarding the wipers as i do...
    Just bought on ebay a wiper system from an 09 A3. Let's see if it solves this problem.
    Regards.
    Vertigo1's Avatar
    Jul 2006
    2,655
    Well the car arrived on Tuesday and these options are indeed in the DIS so I reconfigured the unlocking immediately! The prize for the most pointless option in there easily goes to the "brightness of the footwell lights" - err what on earth!?
    a3_sline_tdi: If you want the setting changed then your dealer can do it although they might try to charge you for a bit of labour - sweet talk them
    My old 56-plate didn't have options for this on the DIS and so I asked the dealer ahead of delivery to configure it the way I wanted. Despite this they still didn't get it right so I marched straight back into the showroom when I collected it and told them to do it straight away as I knew I'd get charged if I went back later.
    micasb's Avatar
    Mar 2010
    312
    Hi there people.
    Problem solved
    Just fitted the new wiper motor/control unit a the service position via DIS works perfectly.
    One more problem solved.
    Regards.
