Sky InsuranceChris Nott
Results 1 to 12 of 12
    tdi-man's Avatar
    Jul 2009
    1,612
    part number needed
    286mm rear solid bake discs part number needed
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    I'll take a look for you but I need the model and year of car.
    I'll assume its for the A3 8P for now.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Rear 286 Brake Disc
    1K0615601M
    The dor a 310x22 Vented rear as well. Thats bigger than my fronts!! :D
    P/N if any one is interested.
    1K0615601N
    tdi-man's Avatar
    Jul 2009
    1,612
    rear discs are for an 06 Audi A3 2.0 PD140 quattro s-line.
    these are fitted to my 54 plate as i uprated all my discs and callipers...
    thanks
    tdi-man's Avatar
    Jul 2009
    1,612
    and brake pad part numbers as well please....
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    I can only go up to 05 plate in work.
    I'd assume its the same part number.
    Someone might be along soon and double check, if not i'll do it when i get home.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    1 set: brake pads for disc brakes
    286X12MM
    1K0698451D
    tdi-man's Avatar
    Jul 2009
    1,612
    many thanks
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Not a problem
    Tenexx's Avatar
    Mar 2010
    Bedfordshire
    9
    Hi there, can comfirm Axios's part numbers, check for 06 reg Quattro.
    286x12mm discs - 1K0 615 601 M
    Brake pads - 1K0 698 451 H if your vehicle has PR code 1KU
    or 1K0 698 451 G if your vehicle has PR code 1KJ
    Not too sure myself of the differences in the pads & don't know how much of a difference your PR code is going to be since you upgraded your discs & pads but that was the info i got off ETKA 7.
    Hope this is of some help to you though.
    tdi-man's Avatar
    Jul 2009
    1,612
    ok many thanks..
    tdi-man's Avatar
    Jul 2009
    1,612
    new rear discs and pads fitted thanks for the info...
    also 2 new intercooler pipes fitted ........and one on order....
    much better.....
