Badger5Chris Nott
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By S3 MRU
Thread: Cold Air in Passenger footwell?
    Nov 2010
    Hi everyone, first post!
    I seem to be having a small heating issue - i'm getting a constant flow of cold air near the centre console in the front passenger footwell. Has anyone had any similar issues?
    Thanks!
    Wozski's Avatar
    480
    I know what you mean - i think i have that too - could be to do with the pollen filter??
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    I also have this problem absolutely freezing cold air what may be causing this?
    Audi S3 8P2 Silver
    BI-Xenons - FBMFSW - Rain/Light Pack - Auto dim package - iPod Integration - 2011 Nav - Electric Folding Mirrors - Rear Park Sensors - Full Heated Leather - BOSE - Privacy Windows - 2011 Console Conversion - My11 Rear Lights - RevD Diverter - Forge DMV14T BOV - ITG Maxogen CAI - BBS CH 18s
    Apr 2010
    St Helens
    310
    hi guys, i have known things like this to happen with cars. as i have my own garage sometimes things like this are caused by blocked pollen filters and deteriorated pollen filters...... strip it down and take a look and see if its block up with leaves and ****e and get a new pollen filter
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Why would this cause freezing cold air to come in if it's just a filter? The cold air stops when air controll unit is turned off
    Audi S3 8P2 Silver
    Sportback owner
    Apr 2007
    France
    492
    The climate control mechanism relies on several motorised flaps operating to direct the air through either the heater or the cooler matrix. If these flaps don't operate correctly, or they are jammed, the air does not flow correctly. Thus, you get air at the wrong temperature. Suggest you consider looking to see if the flaps are working corrrectly, or are jammed with debris. Not an easy task. Anyway, get a look at the flaps if you can by removing the pollen filter and poking around the flaps. If a flap has jammed it looks like a devil of job to get the climate control system out for servicing. Good luck
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Great sounds like a pain in the ass tbh. Not feeling great ATM will give it a try when I feel a bit better
    Audi S3 8P2 Silver
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Is it possible that the pollen filter may be causing this ultimately? I just don't see how
    Audi S3 8P2 Silver
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    update: car has always been serviced at audi... just looked behind the glove box and this is what i can see... i take it this is where the cabin filter goes? there was not even any kind of cover there? like a door?
    Audi S3 8P2 Silver
    Sportback owner
    Apr 2007
    France
    492
    Yup.....looks like your pollen filter is completely missing. I believe that there should be a plastic panel (door) and inside a filter. Time to go see Audi...
    Cheers.
    Wozski's Avatar
    480
    What came of this - as i have a pollen filter in mine but the air is cold and certainly noticeable.
    Do i really need to take the pollen filter out and check the vents inside??
    How would you go about it?
    Is there an eaqsier way - could vagcom check it??
    Sportback owner
    Apr 2007
    France
    492
    Taking out the pollen filter may not after all be a solution. The whole air-management system requires multiple vents, flaps and motors to operate correctly. One thing you could look at is the hot water inlet valve. There is some kind of solenoid valve that lets hot water circulate into the internal heater matrix. This is commanded by the temperature control system. If this valve is not operating, or or stuck closed, then you will get no heating inside.
    Worth checking the valve and the associated fuse. Sorry, but I do not know of an easy way to diagnose cold air problems.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    i get the same prob too could it be that ive put in pollen filter in wrongly as ive just serviced it myself i get warm air no probs in my car if it helps cheers
    ​She is back on the road yay!!
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    I put the pollen filter in and purchased the door make sure the door is clipped on tightly as sometimes the slightest gap makes cold air rush into the car. All sorted now amazing what 14 quid can do
    L_W_WARD likes this.
    Audi S3 8P2 Silver
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    just out of curiosity have you fitted a facelift climate unit?
    edit: nice to see you got it sorted
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Thanks mate. I only fitted a double din one. Not the newer chrome unit but I used the internal board from my single din one as it was all working fine
    Audi S3 8P2 Silver
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    glad you got it sorted mate i think i'll take out the filter and refit it to see if i put it in wrongly
    Wozski's Avatar
    480
    imnot sure if mine has gone back in correctly
    What way should the filter go in
    I have had a play with the sliding door and the cold air comes out but if apply pressure to the door it seals it and stops. I have to find out how to get it sealed properly lol
    Khufu's Avatar
    West coast of Scotland
    5,693
    Elsa mentions the addition of a screw if the catches are broken & no longer support the flap. The cutout end goes towards the electric motor looking at the diagram.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    the side with the cut off corner points towards the centre console. and u really need to make sure that the bottom of the pollen filter acts as a seal over the door. and the clips are all in theyre catches. then it takes a tough push to fully slide it all the way sometimes it seemed like it was clipped in but it needed another few milimetres
    Audi S3 8P2 Silver
    Wozski's Avatar
    480
    ok thanks guys will check now
    Feb 2014
    Hi Guys,
    Can anyone tell me where to purchase this pollon filter cover? mine is missing but when i push the filter inside it heats up.
