Chris NottAH Fabrications
Results 1 to 19 of 19
    Iain 750's Avatar
    Aug 2010
    Stockton On Tees
    75
    Power Fold Mirror Fault.
    Im having a little issue with my power fold mirrors, intermittantly when i turn the switch to open my mirrors only the passenger side one opens, this has only happened a handfull of times but i find it really annoying.
    Any info appreciated,Thanks.
    Iain
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    They do seem to give problems. Is this with the engine on or off?
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    Iain 750's Avatar
    Aug 2010
    Stockton On Tees
    75
    Engine on Heeman.Speaking to the previous owner he had a similar problem but it was with both mirrors not folding out and the car had a new ECU fitted under warranty to solve the problem.
    Iain 750's Avatar
    Aug 2010
    Stockton On Tees
    75
    Anyone else had this or similar problem??
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    only problem ive heard of is the folding speeds, mine are fine anyway do you have acess to vagcom? and does the driver window work when the mirror refuses to fold out
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    27,014
    Drivers has been an issue for a while on 8P's through the years, but not on all cars, as the mirrors work on resistance to stop power being fed to the motor iirc, I speculated the mirror fitment/spring was dragging it so the module thought ok its fully open or closed thus cuts power, also note its worse sometimes when folding with engine of as reckon its not providing enough current to the door modules, if under warranty dealer will swap the door module/s out or mirror itself mate, but some live with it as its not all the time.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    tbh since i got my car teh only time i have used the folding is when i tested the retrofit
    Mods
    Iain 750's Avatar
    Aug 2010
    Stockton On Tees
    75
    Its only happened 4 times since i got the car in sept but it is out of warranty so looks like i will be living with it.
    Cheers guys much appreciate your help!
    27,014
    Can always swap out your door modules, wont be cheap, what age is the car?
    Also if it happened before fella, then its still under warranty imho for the work & part at least for 2 years, worth a check with dealer tbh fella who did the last socalled fix.
    Iain 750's Avatar
    Aug 2010
    Stockton On Tees
    75
    Its an 05 reg. when it happened before neither of the mirrors would fold and windows didnt work so it was repaired under warranty by Teesside Audi who have a really bad reputation at the mo!
    Will give them a ring and ask a few questions 2moro.
    27,014
    I can source door modules for this if need be, would be the 1st port of call for this fault tbh, audi charge 140-180 per side, think can find cheaper if need be.
    May 2010
    2,502
    Quote Originally Posted by Iain 750 View Post
    Audi repairs have a 2 year parts and labour warranty. if the repair was done less than 2 years ago then take it back
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    Iain 750's Avatar
    Aug 2010
    Stockton On Tees
    75
    Thanks guys will ring dealer 2moro and check!
    Mar 2009
    Staffordshire
    1,235
    Sometimes my passenger mirror doesn't fold out but that hasn't happened for a while!
    Not a huge problem, as it's once every few months, if that. Bet it does it tomorrow now
    27,014
    Anyone seen an off white drivers door anywhere lying about, know someone who wants to inspect it :P
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    haha, ive two prefacelift door modules for everything autodim heating and folding id take a reasonable offer on them
    Mods
    Mar 2009
    Staffordshire
    1,235
    Hahhaha, I've got a couple Dell laptops here if you're interested?
    27,014
    Gets things whiter than white
    TFSI's Avatar
    Born to Fish
    South Cheshire
    531
    My 05 and 08 SE's use to very occasionally not fold in or out again when entering or exiting the garage.
    A few seconds wait and they would then operate as normal !! Never got it sorted but a few times i nearly took the mirrors off on the garage door frame.
    2013 1.4 TFSI S line 8V, Brilliant Red, Cruise Control, DIS, MFSW, Dual Climate, Leather, Front Fogs, 18in 5 Twin Spoke Alloys, Welly, Boot and Fishing Rod Racks.
