Badger5JMB Retrofits
    DOLPHIN DIESEL's Avatar
    Mar 2010
    barnsley
    96
    dash light problem, help!
    can anyone help, i have a 54 plate a3 tdi sport. the problem is that the steering wheel light is constantly on the dash board and the steering is very light. im not sure if this has anything to do with it but i fitted an s line wheel to it, i also had to change the slip ring. the car had some lights on the dash when i got it as it had light front end damage, i cant remember if this light was on before i changed the steering wheel but thought it could be causing the problem. ive plugged it in with vagcom and it says steering sensor??
    any help would be great
    drivers side s line fog light wanted for 07 bumper.
    cash waiting
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    Yes it's the steering angle sensor and will need re calibrating AFAIK am sure someone will be along to confirm this.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Mar 2010
    barnsley
    96
    cheers, dude. yeah thats what it said on the vagcom, can anyone tell me how this is done?
    cash waiting
    27,129
    Yes goto ross-tech's wiki & look it up as its on there site or if you have a genuine interface ask RT to advise via support.
    Also yes you need to do the steering angle, possibly lateral sensor.
