AH FabricationsEM Tuning
Results 1 to 12 of 12
    gynads's Avatar
    Oct 2009
    338
    S3 knocking noise?
    Hi all, under spirited gear changes im getting a clunking/knocking, possibly coming from offside front but not 100% sure also feels a little vague with slight knocking when cornering when under power? feels a bit like CV joint? didnt these have a problem with steering racks?
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Yep, rack problems are well documented.
    Be surprised if there are other drivetrain issues unless you have mega miles.?
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    gynads's Avatar
    Oct 2009
    338
    Only 20k Paul. are the racks on a recall?
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    gynads
    So you have a knocking noise when you change gear, Yet you think its the steering rack???
    Try checking your engine mountings first mate as that is more like your problem, the engine or gearbox are rocking back on the mounts when you dip the clutch to change gear causing the clunk and probably a dificult gear change also?
    Engine mounts are visiable either side of the engine but there is a gear box mount out of view behind the engine set to one side I would expect this to be your culprit.
    Has any work been done to the car recently? any more symptoms to work from?
    Gaz m
    Black 996 C4S
    B6 S4
    Black S3 Revo 2+ sold
    All options + Miltek TBE, Revo 2+, HPFP, RNS E, Bose, Alpine Ipod interface, TTRS Brakes
    For sale unfitted Forge catch can kit, open to offers?
    also standard S3 factory exhaust?
    gynads's Avatar
    Oct 2009
    338
    Hi Gaz, I have recently gone for stage 2+. My first thought was gearbox mount. Are these fairly easy to change? Maybe worth upgrading anyway? I'll have a look when i get back onshore
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Ahh!
    You have my problem, never home to fix or drive the bloody cars! Where abouts in the country are you? I havent changed one but a few have on the site so a search will help you for information as to the symptoms they had and the solution used to fix it.
    I would suggest there would be a lot more syptoms if it was a failing steering rack mate.
    There are a few companies that do upgraded mounts for the S3 so that is a good option for the future.
    Gaz m
    Black 996 C4S
    B6 S4
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    If you have just gone Stage 2 then the exhaust must have been changes recently right?
    Could it be that knocking?
    The racks arent recall, just warranty.
    Good luck
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Thats a very good point Paul!
    After fitting they will settle down over a few weeks, and as Paul say's this could also be a cause you need to look at?
    Any other symptoms or information mate?
    Gaz m
    Black 996 C4S
    B6 S4
    gynads's Avatar
    Oct 2009
    338
    Quote Originally Posted by gaz m View Post
    Ahh!
    Gaz m
    ha yeah thats about it! keeps the mileage down i guess! I'm in Lincolnshire bud. I'll do a search.
    Quote Originally Posted by PaulAr View Post
    Good luck
    Paul
    yeah could be, need to get it on the ramp to have a look see.
    Gaz m
    I'm sure it was doing it on stage 2, when i just had the downpipe etc, and after, when i had the rest of the system fitted
    Oct 2010
    41
    I think mine is knocking sort of get a knock when i reverse of my drive on lock I have a tiny half inch curb and seems to knock when I drive over this...
    On the passenger side ... S3 07 plate 35k...
    Jan 2009
    234
    Gynads, if you fitted a Milltek DP, it should come with a Powerflex mount, the one below the gearbox. If the sound started after you fitted the DP, the problem should be easy to spot.
    gynads's Avatar
    Oct 2009
    338
    Ah ok, is this supplied to prevent this knocking? I bought it from a guy on here along with the sports cat, and just bought a new cat back system
